Thanks Tom!
The scarry kind of flat back reflector, may need to rethink my mod plans…
Thanks Tom!
I would look at the C8F MCPCB which Sofirn does sell separately (I got one). It appears to be the same size - no time right now to measure though. If it does align, there's your 3535 triple MCPCB for the X9!
Rough measurements from outside the lens seems to be dead-on.
the usb port is bigger than for example the one on astroluxes or so….its bigger ?
It’s not much larger than the port on the Astrolux lights that use micro-USB, since USB-C is a different connector.
However, you can get more current from USB-C up to 2A in lights(so faster charging for 21700/26650), and a reversible connector
Ôk so I cant use the samé cable…
Sweet looking titanium style light man.
Some specs/mod info for my X9:
More pics from a break down:
Thank you TomE for those infos !
any idea how to make this nice flashlight more bright? which leds should fit without driver change? /dont want to loose usb port/…
Well, I modded my X9 to XHP50.2's, gets ~10K lumens, but I piggybacked in a driver. Looks like the stock driver is FET based, so you could just swap the LED's to XHP50.2's, assuming/hoping it can take higher amps, stock is ~15 amps, XHP50.2's in my custom driver setup hits 30 amps at max.
I don't see any other option for LED's to get more output, and the good thing is the stock driver is already FET based. But again, you always throw the dice when bumping up amps. I'm guessing it should work ok, because 15 amps is already a big #.
this sounds very good…. you wrote to me…is there any pizza xhp50 neutral source? i guess you got them separatly…
Dunno - KD has them in 6500K and 6000K, both CW, same with MtnE. Should be 5000K or lower to be NW. I haven't checked Mouser or Arrow in a long time.
What battery are you using? I wonder if my old blue Littokala cells will even hit 30amps.
LK's won't, GOLISI 26650 though did for me.
any idea where is this flashlight available please? with typical usb ,not magnetic…
Well the old model had USB charging, new model is magnetic. I got one of each but both had the charging removed because of piggybacking in a replacement driver.
Neal lists the old model here: https://www.nealsgadgets.com/collections/amutorch/products/amutorch-x9
but I'd check with him first if it's really USB charging.
BG lists the USB charging model here: https://www.banggood.com/Titanium-Black-AMUTORCH-X9-SST40-XP-L-HD-3600lm-High-Lumen-Flashlight-USB-Rechargeable-26650-Flashlight-Portable-4-Modes-USB-Charging-Work-Lamp-Camping-Hunting-Emergency-Lantern-p-1463001.html?ID=2246143494&cur_warehouse=CN
BG I'd trust less to ship a USB charging version.
One month back order… As many other models…and from neal never again rather…
Do you want my red X9 with xml2 nw?
Where you from? Hm… I wanted reflow it with xhp. Not sure if is there space for it…
