Thanks Simon! Super excited.
No, that’s really ugly!
Glad you have taste Simon. Pineapple knurling looks
My first priority for knurling is grippiness.
I have a Convoy X3 on my desk at the moment. Comparing it with an S2+, the X3’s knurling is much grippier and still looks good. I vote for X3-style knurling on future lights.
The S2+ with Biscotti and 4000K 95CRI SST20 LED is really nice, by the way. It’s my belt EDC now
I much prefer the first Simon’s idea over any big shape (square, diamond, whatever) knurlings that are horrendous (to me) :
…[cut]…
I don’t meant to make a smooth surface.
I just want to change a style, on the one hand, it will improve the product yield, on the other hand, keep the original feel of grip.
For example, I can change it to the following
Simon Mao:…[cut]…
Snap :+1:
Tally-ho:I much prefer the first Simon’s idea over any big shape (square, diamond, whatever) knurlings that are horrendous (to me) :
Simon Mao:…[cut]…
For example, I can change it to the following-
Snap :+1:
Agree, that is a tasteful knurling to me
+1 for the X3 style.
+1 X3 style
It looks boring, but still better then the other designs and seems practical.
Simon,
Not sure if anyone asked you already this question but as you are already working on new S2 host maybe its a good time to ask.
Would you be able to produce a 18350 style headlamp with the head and reflector in the middle?
something like this (TN-20)
or this (EHL0628)
or even like this (S3 “eebowler”)
any chance on codes for 580 lumen convoy s9?
I need 12 asap
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
I need 12 asap
what about S9 2500mA version 900-100lm
@Simon, that headlamp looks amazing!
Would it be possible to order with SST-20 4000k?
If so, it would be awesome!
To: sochi111
max output 2500mA
What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
Maybe, though these are intended for regular non flashlight geeks…
So I am concerned about heat…and cost to an extent…
Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
Simon Mao: justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
So I am concerned about heat…and cost to an extent…Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
$17.69 including 15%off
Simon Mao:To: sochi111
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
yes,long press for off,and single click to change mode
only CREE XML2 version currently
and i plan to produce charging version soon,
SST20 can be adding in plan
Still, thank you a lot!
I’ve been waiting for a Convoy headlamp for such a long time.
I love your lights’ user interface, build quality, and easy modification.
Is it easy to open for modification?
Thank you again.
