I've been waiting for a review on those Trustfire 26650 flames for awhile. Kokopelli did a 1A discharge test and posted here. Sounded ok, but was waiting for a "real" test at higher discharge rate and what max current they could handle.
Ahh! Yes either LiCo or LiMn (IMR) is fine. The King Kongs are actually INR which is another chemistry (which I have very little understanding of) and they are all suitable for the JM07.
Current regulated, seems to be misinterpreted, some believe that current regulated means the light doesn't use PWM.
The body of the JM07-pro is 32mm, that might be a problem with some bike mounts.
I use one KK in the JM07-pro, simply until I cannot use it no more because it stars to flash and goes to low mode.
The problem with unprotected cells is not the flashlights you use them in, is to make sure they don't get over-discharged or over-charged. It would be nice the flashlight you use them in have a low voltage warning and switch to low safe mode.
BTW: I have the ST60, very nice size, quality threads and very bright.
I have several bike mounts - TwoFish Lockblock and CycloBlock are very flexible and will work fine with larger diameters.
I was disappointed that the ST60 was out of stock, but I am happy to get the JM07, as I probably wouldn't have ordered it otherwise. I like the 1x or 2x flexibility of the ST60, glad to hear you like it. I have the ST50 and the quality is great. It's definitely on my next purchase list, probably from International Outdoor Store.
Garry: Believe me when I say I am no battery expert. I did some research on IMR (+ Chicago X taught me a thing or two) and INR and here's what I found out:
IMR is a misspelled acronym for LMR - Lithium Manganese Rechargeable. It is a safer chemistry than Lithium ion Cobalt, which is typical chemistry in most Li-ion cells. Safer because it doesn't vent or go nuclear or flame out. That is why most IMR(LMR) batteries are unprotected. Well that and because it costs money to add protection and IMR is not a big seller like Li-ion Cobalt.
INR is suspected to be Lithium Nickel Cobalt Aluminium Dioxide. Again, INR acronym should probably be LNR. That's all I know, but there is a Wiki article on it here: http://en.wikipedia.org/wiki/Nickel-lithium_battery Last entry was 15 months ago, so I suspect Panasonic has moved it out of the experimental stage. It is also supposed to be safer than Li-ion Cobalt and probably does not have protection built in due to cost. I think the Trustfire 26650 you saw is neither of these, rather it is a good old fashioned Li-ion Cobalt and should rightly have a protection circuit. Doesn't mean it actually works, mind you.
As Hikelite and mitro referred tohere and in another thread, unprotected cells should be ok to use in a flashlight that is regulated to warn you below a certain voltage level (usually 3a) by flashing or dropping to medium or low. My Balder BD-2, Uniquefire 3900 and I believe the JM07 all do this. When the light output dips or flashes, you know to either run in a low mode or replace the cell to prevent over-discharge.
BetweenRides, Thanks for the info! I have never tested "low voltage protection" in my lights (to even know which ones have it and what it's like to encounter it). What about charging? What if the charger decides not to stop at 4.2v? There's no protection circuit to kick in, so what will happen on one of these cells?
The great advantage of the LiMn cells is low resistance, very little sag. If circuits are added then automatically resistance is added. Some 18650 from Sanyo are rated even for 20A discharge, the AW is rated at 16A discharge, hardly cheap mosfets can do such thing, and then as I mentioned resistance is added.
Low Voltage protection also works to identify sh!tty batteries. If I put Ultrafire 3000mAh batteries in my Balder, it starts blinking immediately and won't operate on high. Any good cell will operate the light just fine.
If you are using a good charger, LMR will charge like any other Li-ion cell, should stop at cell capacity around 4.17-4.20 (remember they are just another chemistry of Li-ion and have the same voltage operating range). I have two AW IMR 14500 cells and they perform on the charger like any other, come off at 4.18. If you buy the Xtar charger, you should be fine, but still follow the same prudent charging protocol and don't leave them alone, take off when the light turns green.
Sorry, pounder, we went off topic (as usual at BLF ). If you re-read the OP, I ordered the ST60 (18650), it was out of stock and CNQG is sending me a JM07 (26650). The ST60 can run on 1 or 2 18650's only.
Read the instructions and attach it to your multimeter as suggested.
Short the cell across it and read off the current. If it can't do 10A on a dead short (Should be nearer 45) it is crap. You might be able to read a value before the protection circuit (if any) cuts in.
Whatever you do, don't run this test for any longer than it takes to read the meter.
Really, really don't do this for more than a second.
I disclaim all responsibility for melted shunts/meters/hands/houses.
N.Shock provided a good link below that indicates at least one brand of "INR" branded cells are LiNiCoMn02 chemistry, like the Sony 26650VT cells. They're capable of VERY high discharge rate and are far safer than standard LiCo cells, but can still be volatile if there were a short or a puncture.
Personally, I completely avoid any cell not being explicitly represented as one of the safe chemistry formulas.
That's horrible advice. Even if someone was willing to ruin a SAFE battery with a dead short, which would, permanently increase the cell's internal resistance, what if it was not a safe chem or protected cell? LiCo cells DO vent flames and DO explode, and either/both can happen very quickly. Big cells like 26650's pack A LOT of power - pipe bomb power.
That shunt is meant for measuring voltage drop across it under load as a means to measure the current going across it, not to dead-short a battery, power supply, etc.
To answer question #2 on the first post the only ones are from manafont, they are only 4000 mAh + not the claimed 5000 mAh, but they should be close to the king kongs with mAh.
I have brought one of these just to test out and see if they can be used in series with TR-J12 with out modification unlike the king kongs.
