Is there a code for the pre-order already? Interested to try the Philips Luxeon V model…
interested
Ordered Philips Luxeon model
Any information about mode spacing?
Also, is anybody familiar with Amutorch drivers? What should we expect in terms of efficiency?
Ordered one yesterday and it said “only one left in stock”. Showed to have shipped this morning. Of course we all know how Banggood is with inventory.
Mine got shipped on the 9th, with expected delivery date on the 20th.
Дайте пожалуйста код купона .
interested 1 in SST40, could you please share the coupon freeme.
Thanks
Interested. Haven’t gotten code yet. I’d like to try the Philips Luxeon V LED.
Anyone got this wonder how it perform, UI, tint and beam of Luxeon V ?
I just got mine today. UI is Low-Mid-High + strobe (double click). It does not come with Turbo mode. Luxeon hotspot is larger than XHP35 HI.
Can you measure the throw?
Edit: If you can’t, can you do a beamshot comparing other lights to it, or measure the inner diameter of the reflector?
anybody have this light?
Beamshot comparison with Astro MT02 or BLF GT Mini?
Interested
564m with LUXEON NW emitter. [quote=BlueSwordM] Can you measure the throw? Edit: If you can't, can you do a beamshot comparing other lights to it, or measure the inner diameter of the reflector? [/quote]
Beam shot pls
Woah, that is some serious throw for a Luxeon V.
The XP-L HI must be 850m+ easy.
What is the inner diameter of the lens?
I got mine yesterday and put a Sofirn 4000mah 21700 in it and low, medium and high worked fine then I double clicked and got strobe. Triple click was nothing. I did check the voltage on the battery and it was pretty low. Maybe 3.6v. Hope it was just low voltage. I will check it again tonight. UI is still the same right? L,M,H double for turbo and triple for strobe?
Edit- Got home and checked Amutorch’s site on Ali. The is only low, med, and high. Double click for strobe. Liked mine so much I ordered another today.
Can I please have code
How well does it fit 21700s? What are springs like? Quality FET driver with high frequency not visible pwm? What size mcpcb? Does it have a custom centering ring for luxeon? Is reflector nice or have rings? Is the switch clicky or mushy? Does switch light have any functions if it exists?
Come on Freeme! My mail box is open if u need me to answer these…
