【convoy】H4 and B35AM options are updated
Hi Simon,
Could you please tell if the new Convoy S11 will have 12 mode groups (like current S2/S3 models) or similar?
In general I want wide selection of low light modes, so such a mode groups is a very nice option.
Actually, please please please please please if there are variations in the S2, can we not call it an S2?
Just like the Sofirn SP10, where there was the original, the A version, then the B version, then the colored-B-version which was the same as the renamed-black-A-version, with tweaks to the UI (so original UI, new UI which became the older UI, then the new UI, …) and nobody knew what they were getting until they actually received the light.
Different styles, different knurling, different battery-tube, etc., let’s call it something different?
And please, not just an ‘S’ suffix, which drives me buggy when someone would write “18650S” and you have no idea if they mean more than one 18650 cell or the Folomov 18650S flashlight.
Whew. Now I feel better…
I’m voting for this. It’s much easier to order with strict model/features correspondence. I’m perfectly fine even with something like “Convoy F123DG45” if it would encode all features exactly.
I personally vote for calling the new 21700 S2+ version the “S21”. Plays into the 21700 battery format, and indicates that it is functionally different from the S2/S2+/S3/etc family.
Yeh. And even with the S2/S2+, if they have different styling, different length, different reflectors and pills, even different threads so they’re not lego-able, it can get confusing to those who’d think otherwise. Like, “the ‘+’ just means improved”.
I’d be okay with the “S21” as noted above. Describes it nicely.
Fine by me, as long as it has the shallow reflector of the S2+ and not the deep reflector (which is less efficient) of the original S2.
S21+ then?
valid points, makes sense. but its all up to Simon, hes the boss.
So, where is it?
Another important question: will I be able to use the same optics (both reflector and TIR) with S2+ 21700, which are suitable for S2+ 18650 currently?
Maybe it is worthy to be patient :slight_smile: If Simon has already product images, we will be able to buy it soon. For me it is not a problem if it is a bit later.
Something I’m noticing with the H1 is it only has one small groove that could accommodate a pocket clip, and only in a head-up configuration. I usually prefer my angle lights head-down in my pocket, and a larger groove tends to make the clip more secure.
When it comes time to revise the design, better support for pocket clips, in both head-up and head-down orientation might be worth looking at.
yes,in production
i will get XHP50.2 3V J4-3C and J4-3A soon
each bin 500pcs
no ,i dont have this kind of driver
what LED do you want to be installed in S11?
Good suggestion,i’m ready to name it “S21A”
a little large, but i think if you dont remove the glass lens ,
the TIR still can be installed
i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an example
This is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
So if I bump into things (read: constantly) then I’m not scratching the lens :slight_smile:
i see ,thanks ,i didnt consider this ,i should update it in the next batch
