Fine by me, as long as it has the shallow reflector of the S2+ and not the deep reflector (which is less efficient) of the original S2.
S21+ then?
S21+ then?
I personally vote for calling the new 21700 S2+ version the “S21”. Plays into the 21700 battery format, and indicates that it is functionally different from the S2/S2+/S3/etc family.
valid points, makes sense. but its all up to Simon, hes the boss.
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
So, where is it?
S2+ 21700 is the most interesting to me! Will it be available in various anodization colors like the normal S2+?
Another important question: will I be able to use the same optics (both reflector and TIR) with S2+ 21700, which are suitable for S2+ 18650 currently?
Simon Mao:To: sochi111
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.So, where is it?
Maybe it is worthy to be patient If Simon has already product images, we will be able to buy it soon. For me it is not a problem if it is a bit later.
Something I’m noticing with the H1 is it only has one small groove that could accommodate a pocket clip, and only in a head-up configuration. I usually prefer my angle lights head-down in my pocket, and a larger groove tends to make the clip more secure.
When it comes time to revise the design, better support for pocket clips, in both head-up and head-down orientation might be worth looking at.
Simon Mao: Satan@103TFS:Looking good any C8+ 21700 soon ?
in production now ,about one month
what about s2+, also in production ?
yes,in production
Hi Simon ,what about XHP50.2 6V and 3V in 5000K range ?
i will get XHP50.2 3V J4-3C and J4-3A soon
each bin 500pcs
Hi Simon,
Could you please tell if the new Convoy S11 will have 12 mode groups (like current S2/S3 models) or similar?
In general I want wide selection of low light modes, so such a mode groups is a very nice option.
no ,i dont have this kind of driver
what LED do you want to be installed in S11?
andr3w: Lightbringer:if there are variations in the S2, can we not call it an S2?
I’m voting for this. It’s much easier to order with strict model/features correspondence. I’m perfectly fine even with something like “Convoy F123DG45” if it would encode all features exactly.
Yeh. And even with the S2/S2+, if they have different styling, different length, different reflectors and pills, even different threads so they’re not lego-able, it can get confusing to those who’d think otherwise. Like, “the ‘+’ just means improved”.
I’d be okay with the “S21” as noted above. Describes it nicely.
Good suggestion,i’m ready to name it “S21A”
Convoylover:S2+ 21700 is the most interesting to me! Will it be available in various anodization colors like the normal S2+?
a little large, but i think if you dont remove the glass lens ,
the TIR still can be installed
i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an example
This is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
So if I bump into things (read: constantly) then I’m not scratching the lens
Simon Mao:i thought head-down was useless, so i just add one groove.
Where do we use head-down? is there an exampleThis is for using a right-angle light as an everyday carry light in a pants pocket. Head-up usually results in a large amount of the light sticking out of the pocket, where head-down does not.
i see ,thanks ,i didnt consider this ,i should update it in the next batch
Satan@103TFS:Hi Simon ,what about XHP50.2 6V and 3V in 5000K range ?
each bin 500pcs
What about XHP50.2 6V K2 5000k ?
I need H1!!! I want H1!!!
S11 up! Aaaaaand purchased
hello Mr Simon Mao, I see an interesting silver S2+ for 21700 size in your photo! Is this for sale yet?
No, it isn’t if it is not on his site. This is the 1st picture I’ve seen of it, the S21A
