This is great. When did they change it? Or am I crazy? I remember a different UI from when this light was released. The UI you explained is a lot like Olight and Acebeam.
They came out with this new v2.0 using the XHP50.2 last November.
The first version used an xpl I think.
Wasn’t it click for on, click to cycle through modes, and long press to turn off? I think we had this discussion on another thread regarding the XHP50.2 version. I mentioned that the UI was a deal breaker because my E-switch lights all have almost the same UI. Except for some that have ramping firmware obviously. I might be wrong though…
You might be thinking of the older v1.0 light. I never bought that version because I don’t like that UI either.
Maybe we where talking about v2.0 before it actually came out so the written description was incorrect and we all assumed the wrong thing.
Thanks JasonWW
I created some kind of a UI chart for the SP33 V2.0 (XHP50.2)
A few more notes.
You can go from Eco mode to Turbo.
Double click from Turbo activates dual frequency Strobe.
From Strobe, a dbl clk goes back to Turbo. A single click goes back to last used mode.
That will complicate your diagram.
Thank you Jason! I will be glad to complete my chart.
And yes, it will be challenging to find some space for the missing parts of the UI.
Hello my dear friend!
Banggood is selling their stock of the
Fireflies E07 ONLY US$ 49.90
7 x Nichia / XPL 6900Lumens
Product Description:
- Made of 6063 aluminum alloy and 304 stainless steel
- Body color: Matt Black , Grey and Desert Yellow, Silver
- HAIII Anodising Surface Finish
- 1x 21700 / 18650
- 25 degree angle TRI lens
- 98% AR coating glass lens
- Digital current regulation on lower brightness
- IPX6 waterproof
- with Aux leds ; with switch leds
- Size: 112mm(L )x 37.5mm(Head) x 26mm(Body)
- Net Weight: 125 gram
Package included:
1 x Flashlight
1 x O rings
1 x Stainless Steel clip
1 x Landyard
1 x Gift box
use my CODE: BGFIRE to get the discount!
XPL NW 4000K/5000K only US$ 49.90 ($83)
XPL CW 6500K only US$ 49.90 ($83)
Nichia 219B R9080 CRI98 US$ 49.90 ($73)
please note: not all combinations (color vs. LED) are available
only few flashlights are left!
look here for 21 more deals!
Fireflies E07 with XPL-Hi @ $49.90 would be a really good price… but I notice BG does not have stock at the moment…
Desert Yellow with XPL NW 4000K is still available.
“Only 1 pcs left” so better be quick
seems the last have been sold...
Ordered the silver SST-20 95CRI version. Thanks!
Hello my dear friends!
Members know: here are 2 new deals for you!
(the links in the pictures take you to the shop for more information)
WUBEN P26
XPG3 500 Lumens White
365nm UV Light
Dual Switch
some of Wubens Ads:
and the:
Haikelite MT09R
3x XHP70.2 with 25000LM
BLACK/BLUE and WHITE/BLUE
available Tint: 5000k and 6500k
Features:
[1] By default the MT09R is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Package included:
1 x Haikelite MT09R XHP70.2 3 x LEDs 25000LM LED Flashlight
1 x Screw
1 x O-ring
1 x Lanyard
the ORIGINAL BLF Q8 – only $44.99
veröffentlicht am 29. March 2019 in Allgemein, banggood, EDC, flashlights von m4d m4x
A real monster flashlight and result of a flashaholics project is ON STOCK and sold for a nice price!
(valid only 10 days!)
BLF Q8
4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
my Code: BGQ8 my price: US$ 44.99
(MRSP: ~$80)
Specification:
Product name: | BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight |
Brand: | BLF |
Model: | Q8 |
Emitter Type: | XP-L HD V6 3D |
Light temperature: | 4750K-5000K |
Light color: | Neutral White |
Mode: | Smooth ramping or mode set operation |
Material: | Aerospace grade aluminum alloy construction |
Total Emitters: | 4x |
Battery Configurations: | 4 x 18650 or unprotected button top (not included) |
Working Voltage: | 3-4.2v |
Switch Type: | Electronic switch |
Switch Location: | Body side of the flashlight |
Peak Beam Intensity: | 30000cd |
Impact Resistant | 1.2meters |
Max Output: | 5000+ lumens |
Range: | 450+ meters (max) |
Lens: | High transmittance glass |
Reflector: | Aluminum alloy mirror reflective cup |
Waterproof: | IPX-8 waterproof |
Color: | Black |
Weight: | 400g without battery |
Size: | 132mm x 59mm x 50mm(length x head x body diameter) |
Features:
• Compact and lightweight 4500 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
Mode Groups: | Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data ) | |||||||
Group1: | Moon 2LM/1500h | Turbo 5000LM/40min |
Group2: | Moon 2LM/1500h | Low 160LM/33h | Turbo 5000LM/40min |
Group3: | Moon 2LM/1500h | Low 70LM/66h | Mid 1250LM/8h | Turbo 5000LM/40min |
Group4: | Moon 2LM/1500h | Ultralow 10LM/150h | Low 160LM/33h | Mid 1500LM/6h | Turbo 5000LM40min |
Group5: | Moon 2LM/1500h | Ultralow 10LM/150h | Low1 70LM/66h | Low2 160LM/33h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group6: | Moon 2LM/1500h | Ultralow 5LM/150h | Low 70LM/33h | Mid1 240LM/17h | Mid2 1100LM/10h | High 2500LM/3h | Turbo 5000LM/40min |
Group7: | Moon 2LM/1500h | Ultralow1 10LM/400h | Ultralow2 35LM/140h | Ultralow3 95LM/54h | Low1 160LM/33h | Mid 1350LM/8h | High 2500LM/3h | Turbo 5000LM40min |
Group8: | Moon 2LM/1500h | Low 160LM/33h | Mid 750LM/17h | High 2100LM/5h |
Group9: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 520LM/20h | Turbo 5000LM/40min |
Group10: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group11: | Moon 2LM/1500h | Low 160LM/33h | Mid 1350LM/8h | Turbo 5000LM/40min |
Group12: | Moon 2LM/1500h | Ultralow 5LM/600h | Low 150LM/33h | Mid 1700LM/5.5h | Turbo 5000LM/40min |
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Product review from BLF Forum:https://budgetlightforum.com/t/-/39069
today i present the all new
Sofirn SP70 for just US$ 50.-
XHP70.2 With ATR 5500LM
2 Groups: 6Modes or stepless 2 to 5500Lm
Ultra bright Tactical 18650 or 26650 LED Flashlight
use my Code: MSP70 to get the discount
the following deals can be found here: M4D M4X deals
(the codes will work as soon as they are ready to buy)
Sofirn C8A / C8T / C8F Tactical Flashlight
Sofirn SF32UV Nichia 365UV 365nm LED
Sofirn SD02A XPL 3000K Professional Diving Flashlight
Sofirn SD02 XPL 1050lm Professional Diving Flashlight
Sofirn SF13 New Version LED Flashlight AA XPG2 420lm EDC
Sofirn New SP32A XP L2 1300lm 2 Groups V2.0
Sofirn New SP32A Powerful LED Flashlight 18650 Flashlight XP-L2 1500lm
Sofirn SF34 Powerful LED Flashlight 5 modes
Sofirn SF31 XM-L2 1000LM 5 Mode
Sofirn SF11 Powerful LED flashlight Tactical Flashlight AA Torch XPL 1100lm
Sofirn New SC31 XP-G3 4 Modes USB Rechargeable
Sofirn SF10 Portable LED Flashlight 14500 Mini flash light AA XPG2 420lm 5 Mode
Sofirn New SP10 XP-G2 550lm 6 Modes V2.0 EDC LED Flashlight AA 14500
Here is the thread on the SP70 if anyone has questions.
(Note: Most questions have already been asked so try searching first).
Looks like a Lego host….still going to buy one.
