Another vote for redundancy. Stock H03 in the go bag with cr123as, Q8 in the trunk, D1S in the glovebox, modded H03 in my EDC backpack, D4 in my EDC laptop bag, D4 always clipped in my pocket, and a C01 on my keychain. I won’t be without light haha
IMO, I’d say a modded 1x 7135+6x7135 SST-20 Convoy S2+ potted with dual BeCu springs and a simple mechanical switch, and a 3500mAh cell, with lubed high quality O-rings, ULCp AR lens, and smooth reflector.
You would be getting an efficient light in general, no standby drain, good usable throw, very low moonlight for efficiency, very good durability.
An EDC for light IMO if you were able to find a good buck-boost driver for a Convoy S2+.
uh, i usually have 20 or 30 other lights on deck or in the bullpen-at least at home
also in about 3 alternate locations - bedside, kitchen, downstairs
if in the car, 2 more
if on foot or bike, i have bike light, or bike light plus photon keychain light
one thing i might not do is depend on rechargeables that do not get used much
some of my car and home lights are either li primaries, or C cell, or AA, something like that
now you have to ask about b atteries — what batteries WOULD YOU TRUST YOUR LIFE TO
More parts and more electronics = more failures. If your life depends on light, it’s not a matter of brand but more a matter of diversity : don’t put all your eggs in the same basket.
Driver & LED, incandescent bulb, carbide lamp, kerosene lamp or oil lamp, candle, etc.
Myself and my family have never been in a life threatening situation that could be eliminated by having a torch. Like, has SOS mode ever saved anyone? On the occasion we go camping or have a blackout 1 light just won’t cut it. I’m not going to have a dozen surefires or elzettas on hand for that.
lol no not at all, don’t worry! I knew it was an impractical test… lol it was just cool to watch it crushed by a car in a block of ice…. this is a totally impractical test but because it looks cool it must be worth something! :smiling_imp:
lol anything to help justify yet another light purchase to the misses!
I’d go with Zebralight. I’ve never had one fail, and they’re solid with potted electronics.
I might also say Armytek, because they use massive amounts of metal. But although mine are fine, I’ve heard too many stories about them suddenly dying.
Though for reliability, I’d rather go with two budget lights than a single expensive light. The chances of both failing at the same time is a lot less than a single failure of an expensive brand.
PRIMARIES ARE THE ONLY CELLS I TRUST MY LIFE ON. CR123A CELLS for life critical applications only.
I do have a few dozen AAA Energizer Ultimate Lithium primaries for my Surefire Titan and Surefire Titan Plus. I run Eneloop pros in them now.
I can also replace the (2) Li-ion cells out of my Olight M3XS-UT (and use (3) or (4) CR123A cells in it.)
In my Olight S1 Baton, I can replace the Li-ion and use (1) CR123A cell in it.
In my Olight S2 Baton, I can replace the Li-ion and use (2) CR123A cells in it.
If there were less than optimal other charging solutions.
Only my Olight X7 and my Emisar D4 XPL-HI have me locked down to 18650 Li-ion cells. All other lights I own run solely on CR123A cells. Due to the fact they are WML’s or hand held tactical lights.
You can actually do the entire house for about a grand…….IF you are building new.
Believe it or not, use paper backed aluminum sheet that can be found in industrial supply houses. Put it between the gyproc and the studs. Down side, the cell phones are useless.
I never only have one high quality light on me so redundancy can be thrown out of this equation. I carry at least 3 Surefires on me when I am out, and sometimes the M3XS-UT depends on what I am doing. I am not looking for a single light to carry only one light. That is already a WML. And I carry others also a D4 and 2 more Surefires. If those 3 Surefires and the D4 all goes out, EMP hit.
