I am a bit disappointed in sofirn, i bought an SP36 almost 2 weeks ago on their AE store and it showed as ‘in stock’
Next day i received a tracking number, but until today no result, so shot them a message, their reply was, sorry the item was not in stock, we will ship as soon as we have it on stock…
@kawiboy, Nice to read you got it open that easy! did you use that bended bodkin, or what tool is it?
Did it require much force? Did you need to heat up the light first? Did you need to push through the button hole? It’d be nice if there’s an easy way to get the driver out.
It was a while ago, but I believe I went thru the LED wire holes with a solder pick, poked the driver loose - no difficulties I recall, but I've done it this way many times on glued up drivers. Sometimes it needs light taps from a hammer, but the solder pick is not a very rigid tool - mine is a bit bent up from abuse over the years. In general, I always keep the solder pick to the outer edge of the driver to minimize potential damage. 99% of the time there's no damage, most of the time gentle force is enough.
I think you are referring to the SP33 now, since you cant really remove the reflector of the SP36 without damaging it, since it is screwed from below. THIS was how you opened the SP36
Nope not really much force was needed, nor did I use any heat….
I removed the switch and pressed directly down as close to the driver ring as I could get, if you look between L- and L+ you can see the copper shinning thru the masking where the pick made contact. It didn’t take what I would call excessive force, even though I was pumped up for a fight!
First I pressed slow and steady I heard a faint pop, then during the second press it popped out cleanly. Lucky the driver wasn’t glued and then press fit, witnessed by the glue around the outside edge on the driver board, so initially the driver had to be kind of sloppy/loose to the diameter of the driver pocket. The glue couldn’t penetrate the ano and the single point of pressure peeled the two surfaces away from each other.
I thought about taking one of my long punches and striking it with my small brass hammer, but the angle was to drastic and didn’t want to take a chance of knocking something off the board, ripping the contacts off the board along with what ever SMD got ripped off and launched…I thought it thru and decided, it wasn’t an option after all.
You can see around the drivers face what glue was left behind on the driver shelf, it flicked off with out much resistance also. I have had better battles with pressed in drivers then what this one gave me really, I was totally surprised, shocked, ecstatic and relieved at how easy it was to be honest.
Check them out, hopefully, maybe, if your lucky, they are not soft, you don’t want them to bend, the good ones are Hardened, you have to use a diamond hone, finishing stone, grinder or sander disc/belt to sharpen them, a file will not do it effectively. The Craftsmen picks I have are old and are the hardened type, so I can use them as scribes to do layouts, quite happy with them all these 20+ years….that ad was just to give a visual of the set I have. So check them out and report back it’s only $2.00 bucks!
I have tried it similar but without a result. Which tool did you use to get the driver out? Can you make a picture?
I am thinking about bending a nail to use a hammer and the nail throu the switch hole.
It seems like it should also be possible to pull the driver out by putting a hook through the two middle holes in the driver and pulling, but I haven’t gotten that to work. Nothing thin enough to fit through those holes seems to be strong enough to work.
Yes I was thinking about this too. And I had the same problems like you, finding something for this job.
It have to be strong enough and deep enough.
The Driver is 2.5mm thick and the holes have a diameter of 0.8mm.
Perhaps it is possible to drill the holes a bit bigger. It seems that this holes are no vias. One is in the LED+/Bat+ area next to many vias and the other is at the LED- area next to the AMC7135.
I bought this holster from the Sofirn Aliex store (large size) as recommended for the SP36. It is made of thick material (nylon I believe) and has a velcro belt strap that is easy to use and stays attached well when walking. A plastic d-ring is also included with the large version, I have not used this yet but is appears strong and well shaped.
The SP36 fits well in the holster and the cover flap closes snugly with strong velcro. I like that you can insert the light either direction depending on preference and still have a secure fit.
I usually store my SP36 in the holster and if I need to bring it somewhere I feel comfortable putting it in a center console or glove box and the holster is thick enough to prevent and scratches or damage.
Well, he is in RAMPING mode (that’s important to get the right setting table)
hold the switch to go into settings. Here 4sec. (On lamps from Texas Ace you must hold 16sec)
Wait till the lamp does a doubleblink followed by 3 blinks. That is the stepdown menue.
2.1 klick 3 times to choose timed stepdown
2.1.1 in timed stepdown the lamp waits for clicks. I think he clicked 2 or 3 times to set it for 1,5min or 2min stepdown
the lamp blinks menu #4 = strobe settings. Here he does nothing.
The lamp does 4 quick blinks to signal configuration is done.
But I dont know what he is saying.
What is the problem to understand, Barry?
It is basically walk through this table.
It helps when you have the table in front of you when you try to set up sth. Or you write down the exact click sequence before you try.
