Convoy C8+ Review
23 posts / 0 new
lumenzilla
lumenzilla's picture
Last seen: 12 hours 19 min ago
Convoy C8+ Review
Convoy C8+ is a successor of Convoy C8, utilises a XPL-HI  LED with 2800 mA output from single 18650 battery and has many improvements on host/body design.
I got a Convoy C8+ from DD4 in sand brown colour for reviewing purpose about three weeks ago and here’s my report after using either in urban or jungle environment.
Convoy C8+ Overview
Convoy C8+ can be easily distinguished from its previous version (C8, without “+” sign) by its entire appearance.
Convoy C8+ hands on
The newer version has full of fins on the head for better heat dissipation, aggressive knurlings for better grip, and new U-shape design on its tail cap for easier clicky operation.
The dimension is not very different with previous version and still using reverse click switch. I have replaced the switch board with the lighted one (blue) and using transparent rubber switch.
This sample product has XPL-HI V2-1A 6500K for the emitter with AR coated lens and smooth reflector.
For the engine, Convoy puts a Biscotti driver with 8 x AMC7135 and secure it with brass retaining ring.
What I like from Convoy brand is they don’t glue any part of the flashlight. Disassembling C8+ host is hassle-free and can be done with very minimal tools.
With or without knowledge in electronic, anyone can modify Convoy C8+ to fit their needs.
At Convoy’s online store, we can purchase stainless steel bezel, short body tube to accept 18350 battery, easy to install switch board with LED to create lighted switch, and also replace the reflector with orange peel one.
Operating Convoy C8+
With newer firmware, we can customize how we will use Convoy C8+ by selecting a group from 12 pre-defined group modes.
To choose a group mode, we must enter the programming mode first. To enter into programming mode, turn on the flashlight by fully press the switch and tap several times until the light start to blink.
In this programming mode, we can select the desired group mode and turn on or off the memory feature.
My choice is group mode number six where the flashlight has 3 different brightness mode (100%, 20%, 1%) and disable the memory feature.
Convoy C8+ Beamshots
Convoy C8+ is a true thrower flashlight, period. The beam is very focused and very little spill around the hotspot.
1 percent output:
20 percents output:
100 percents output:
Summary
Convoy C8+ is good and affordable thrower flashlight with four different tint colours offered. Because of its beam profile, this is a good flashlight for long distance illumination like search (SAR) mission. It’s not ideal for EDC and close range illumination.
It’s available in black and dark brown body colour and is highly customisable.
Pros:
  • Good build quality
  • Affordable
  • High output
  • Long distance
  • Customisable (easy to mod)
Cons:
  • OEM packaging
  • Not ideal for close range illumination because the beam is very focused with very little spill
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 12 hours 15 min ago
Great review mate! Thanks
duramax
Last seen: 1 month 4 days ago
cool review, thanks.
firedome
Last seen: 8 months 3 weeks ago
Nice review, thanks!
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
Jack Kellar
Jack Kellar's picture
Last seen: 3 hours 18 min ago
Not seeing much practical reason to get this model over modding my C8 to Biscotti, but still really cool. Good review, only disagree that I’d put mine on mode group 10 with memory Silly
caplang
Nice review!
Jerommel
Jerommel's picture
Why is it called C8+ while it’s a totally different design than the C8?
Lightbringer
Lightbringer's picture
Last seen: 1 hour 21 min ago
S2 vs S2+?
Sillen
Sillen's picture
Last seen: 13 min 42 sec ago
C8 plus cooling fins?
Jerommel
Jerommel's picture
Hmm… So the Revtronic F30B is a C8 too?
I think the 3 lateral ridges on the head and the tail cap make a flashlight a C8.
Jerommel
Jerommel's picture
Does it LEGO with the C8?
BrySig228
BrySig228's picture
Last seen: 1 year 4 days ago
All I want is L6 in this color.
Nice review Thumbs Up
lumenzilla
I don’t have C8 at this moment but I will let you know once I find it out.
Jerommel
Jerommel's picture
Thumbs Up
If so, maybe i can get a black battery tube from Simon, for my Sofirn C8 triple head with Convoy tailcap and tube.
We’ll see. Smile
Plotthound
Last seen: 6 days 7 hours ago
It does with my Convoy C8.
Mikeadoo
Last seen: 5 months 6 days ago
Nice review! Just ordered one from Simon but I am getting an OP reflector with mine and I can’t change my order…. Oops :-\
Do the older or regular C8 reflectors work with the C8+? I’ve never owned a Convoy C8, this is my first.
I have Thorfire C8S that I THINK I might have an extra SMO reflector laying around.
Anyone know if older Convoy or Thorfire reflectors work with this C8+ light?
Mike
BlueSwordM
BlueSwordM's picture
Last seen: 12 hours 54 min ago
They should work no problem.
Mikeadoo
Thanks! What would the OP do with the HI LED in there? Just smooth out the beam pretty much with bigger hot spot area?
Mike
Jack Kellar
It’ll only give a bit more corona and smooth out the beam section transitions. Beam intensity loss should be minimal. I have a C8 with OP reflector, and in lower modes it’s a treat to use at closer ranges.
Mikeadoo
Thanks guys Jack. I have a Thorfire C8s with OP but it has a dome on the LED (not sure what LED, but I know it’s not the HI).
Nice neutral tint. I really like it. It is modded by fellow BLFer but gets kinda hot on turbo…. to be expected. Stock on high got very hot everywhere.
I figured I’d give it a shot since it looks like it might have better cooling than the Thorfire C8s… dunno.
Also the Biscotti seems pretty awesome.
Beer
Mike
Mikeadoo
Oh and do the Convoy lights have that delay when switching modes like the Thorfire C8s? Not a huge deal, just annoying sometimes.
Mike
Terry Oregon
Terry Oregon's picture
Last seen: 1 hour 28 min ago
By coincidence, I just received a sphere-calibrated C8+ from BLF member maukka. This C8+ will help me check the accuracy of my Texas Ace Calibrated Lumens Tube. This was with the 4000K CRI90 Nichia 219C. 7135x6
Here's the reports maukka sent me - as an added reference point - which gives an idea of actual output.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
lumenzilla
On mine (Convoy S2 & C8+) there’s no delay on the switching.
