Hmm, sounds pretty simple. I might have to try this. Do the black flat burn up at 5A? It might be too risky to try a high drain. Unless you’ve got a spare emitter, of course. Lol
Anyone else having trouble with their Micro? Got one in the mail and with the body fully seated it bypasses the driver and runs directly off the battery, loosened very slightly it works correctly
Sounds like someone got a bit overzealous with the solder and it is causing a short someplace. Only way to know for sure is to pull the light apart but that is not super easy.
Got my GT micro two days ago. Love the form factor and that beautiful reflector. It will get a narrower led though, a White Flat (for max throw and wows) or dedomed XP-G2 S4 3D (for much better tint), not decided yet.
I haven’t seen a de-domed Cree emitter that had better tint than the White Flat. Not hot de-domed nor chemical de-domed and certainly not anything that started life in 3D trim. Not even as a result of Vinh’s cherry picking… one of those is sitting on my work bench gathering dust even now, pulled ftom a TK61Vn due to it’s sub-par tint.
Of course, one man’s trash is another man’s treasure…
Got it apart, inspected and everything looks good physically. Even did a factory reset but it is still not working correctly, turns itself on sometimes too
Almost has to be the reflector touching the negative lead OR a split in the negative leads insulation allowing it to ground out. (Look for this where the lead comes through the emitter shelf and bends to reach the pad.)
As an aside, operational instability can easily come from excess pressure by the switch boot on an e-switch.
Yay, got mine today! Well, delivered this past Friday but just got it and am playing with it today.
Quick question, though. The beam…
Is it supposed to be nicely focused, well-defined hotspot and faint but uniform spill? Or is it supposed to have 4 faint “petals” and pretty bright and “leaky” corona?
Based on the hotspot, it seems well-focused, bright circle, faint bluish dot in the center, but the corona seems awfully bright. Even my silly cheap-ass C8 clones have a sharp hotspot and uniform faint spill. Same with my P30 (reflector size more comparable).
Love the color, so ain’t complaining about that, just not sure about the focus, whether a little shaving this or shimming that might help.
The "faint bluish dot in the middle" doesn't sound good. I've only seem that on a bad XPL HI (damage). Some pics, but auto white balance, etc. - tints don't actually look that extreme.
Yeah, the bottom pic is kinda what mine looks like, a “leaky” corona vs a crisp well-defined hotspot vs spill.
I’ve seen the bluish center dot on quite a few lights, no damage, just the light-profile of the emitter vs shape of the reflector, I imagine. Very faint/subtle, really need to move the beam around vs staring at it to catch it. But that’s always been telltale of a well-focused beam.
Just seemed odd about this beam. Maybe it’s the size of the chip vs size of the reflector, dunno.
I’ve not been able to read the thread just yet but I do have a question concerning Sanyo 14500 batteries, which I’ve searched for but can’t find.
Does the GT Micro have issues with unprotected cells? I get flickering with my Sanyo 14500 battery :S Also, if I knock it lightly it seems to lose contact and switch off.
