SST-20-W35H-A120-J4352 Luminus Devices | Mouser
SST-20-W35H-A120-J4352 Luminus Devices High Power LEDs - White White 3500 K 95-CRI, SST-20 Series datasheet, inventory, & pricing.
lol
+10,000 . We never mentioned “get incredibly annoyed by green” either…Personally, I just Do Not like green… that is all. Period.
And as Eraursls1984 mentioned, it has nothing at all to do with the silly, tired, overused, & greatly exaggerated term… “White Wall Hunting”.
If a ‘greenish tint’ Does Not bother some of us…. wonderful.
If a ‘greenish tint’ Does bother some of us……. wonderful.
But neither group need tell the other it’s raining when it is actually something else running down their back. :face_with_monocle:
Guys sorry, sign me out. Circumstances…
Gotta chime in, if 4000k SST20 is too green for you (it was for me), you might be satisfied with 3500k SST20 from Mouser. Still 95CRI, still a hint of green, but pleasantly disappears when there is no other lights to compare to.
When people said 4000k was hint of green, IMO it was awful and I would guess has an awful R9 value, there is just no red, not even yellow. The 3500k is much closer to what people describe as a hint of green, it is pure white but held up next to an incan you think “ahh there is a hint of green”.
…When people said 4000k was hint of green, IMO it was awful and I would guess has an awful R9 value, there is just no red, not even yellow. The 3500k is much closer to what people describe as a hint of green, it is pure white but held up next to an incan you think “ahh there is a hint of green”.
Actually the 4000K has an excellent R9 value.
You can really see it when you shine 4000K SST20 on anything red. The red really pops. Much more so than any CREE led found in flashlights.
Bottom line is red looks absolutely great with the 4000K SST20. The problem is all the whites look a bit greenish.
I agree
I want to sign up for one as well
Interested, albeit probably a year or two late…
Who could this be?
IF it ever comes into fruition.
I’ll have one in SST 20. and if they do one in Nichia 291B.
I’ll have one there too.
I think I did put my name down in the beginning but that was yrs ago
feels like.
It’s a bloody loong wait for a little “Very nice” looking torch.
NOT interested in Throw or spread, just want a nice little, “in pocket” torch
with pleasant Natural looking 291B colour.
@Macka17…… Yep, good memory; you were down for one already.
From post #4….
1 MRsDNF: 85
1 Macka17: 675
1 MagPap: 692
I’d like a SST20 if/when.
Does this get me on the list LOL
Recommended batteries?
OP says short and unprotected…Samsung 30Q? 18.3 mm diameter may be tight?
If the answer is emitter dependent, am most interest in getting both with XP-L HI 3D.
Also, will the FW3A have a low voltage protection circuit?
Sorry, in advance if this was already addressed.
1. Samsung 30Qs will not have any problem fitting.
2. Yes, there is Low Voltage Protection(LVP).
In for LH351D!
How much more floody will the LH351D be compared to the SST-20 under the Carclo?
If you review the very first post, it has a simulated comparison of the XP-L HI to the LH351D. The SST-20 should be similar to our slightly more throwy than the XP-L HI.
If the FW3A becomes available with SST-20’s and you’re thinking of modding it with LH351D’s, consider slicing the domes for more throw and better tint.
Thanks
Preferably a flat top, unprotected cell. Button top may or may not work since some are taller than others.
If you want the highest turbo output, but also the highest heat and shortest time, go with a high drain. (VTC5A, 25R, etc…)
If you don’t care about squeezing every last lumen out on Turbo mode then a high capacity cell might be better. (MJ1, 35E, Panny GA, etc…)
The 30Q is not quite a super high drain, but is a nice mix between the two. Same for VTC6.
I think most folks will use the 30Q as it’s a proven reliable cell, works well, is cheap and is easily available.
- Samsung 30Qs will not have any problem fitting.
Thanks, BlueSwordM! :+1:
