WTS: Calibration lights for DIY integrating spheres / lumen tubes - 67 € -
Ah… not the usual Viltrox
Is there an available set still? If yes, I would like one
Just discovered this thread
Replied and shipped.
I’m running out of lights soon (two sets left), but ordered some more S2+ and BLF348. Also got ordered a couple of Convoy C8+ with 4000K CRI90 Nichia 219C. If someone wants check the integration properties of their sphere with a throwier light this could be a good option. It can also replace the BLF348 in a set.
Unfortunately with the C8+ the package will exceed the maximum thickness of 30mm for a small letter so the shipping costs will be a little higher. Around 7-16 € more depending on the buyer’s country. Also the light itself is pricier than the other two. That’s why I just got two for now. S2+ and C8+ together as a set would be 81-90 €.
PM sent.
One C8+ measured and ready to go. On its own, the price is 50 euros if you previously bought a set.
Well, I’m finally joining the calibrated-meter club. Pretty soon, people should be able to expect much more accurate measurements from me.
Nice, are you building your own integrating sphere?
/\…. :beer:
No, Dale took pity on me and is sending a nice calibrated lumen tube. It’ll put my “integrating milk carton” to shame, and eliminate the need to use my other device, the “integrating bathroom”. I also finally ordered some calibration lights to go with it, which might be here by the end of the month.
So… I’m basically joining the club because I got a kick in the pants. But, like, in a nice way. :slight_smile:
TK :smiley: :+1:
Dale as in DB Custom or do you mean Texas_Ace?
Dale as in DB Custom. I don’t actually know any names for Texas_Ace aside from his BLF name.
lol, Even in real life I am called TA, been that way forever, my screen name actually came from that.
I didn’t think Dale had a spare integrating sphere/lumen tube. I think TA did. That’s why I wasn’t sure. Anyway, I see Dale is talking about building a new one. Maybe he’s giving you the one built by Manx Buggy. If so, it is a the pvc unit with no diffusers. It tends to read a bit higher for throwy lights compared to floody ones. Then again, he might have built you one from scratch. Oh well, tell us about it when you get it. I’m curious. :+1:
Remember what “curiosity” did to the cat…… :wink::beer:
More specifically, Dale and the brothers R decided I needed one, so they made it happen. If I understand correctly, it’s a brand new lumen tube and meter, full of diffusion sheets, calibrated with maukka lights, which should read out lumen numbers directly on the meter with no multiplier.
Of course, things may settle and shift a bit during shipping, so I’ll most likely recalibrate it myself to be sure. I needed to get some calibration reference lights anyway… so both tube and lights are on the way.
It’s a pretty huge upgrade from my current gear.
Maukka I was wondering. Do you have to recalibrate your sphere each time you use it with that “Lisun’s SLS-10W standard light source”. The reason I ask is some how I have found my 3” lumen tube way out of calibration again and I am not sure why. Everything is in the exact same place it has always been. The tempreture in my shop is up a little right now, but for most every test I do I put the lights and batteries in the house for a day before testing. I understand that absorbtion has to be calibrated for, but I’m even getting a different set of numbers on the same lights (such as the calibration S2+).
Did you try changing the batteries in your meter?
I always calibrate befoore taking measurements. Not with Lisun bulb but with three calibration lights to make sure everything is in order. There is usually some variation (a percent or two maybe) between sessions but as long as the correction factor between the lights doesn’t differ more than half a percent, everything is go. So there hasn’t been any lomg term drift for me and I also use an S2+ as one of the cal lights.
Dust is an issue I have, I have to clean my sphere every week or so to keep readings the same.
