TK's Emisar D18 review -- 3x18650 photon grenade
That is not the material that is being used in the D18. :wink:
Thanks for that teacher :+1: that’s cleared that up , I thought it was probly a joke as I could clearly see through it ,tinterweb & forum talk can be a bit confusing at times.
No problem my friend, glad to be of assistance. :beer:
Things certainly can be confusing at times… I agree. :wink:
What I was trying to say is that the material I posted in the pic, in the same thickness as the spacer board in the D18, would probably be see through. As you can see in the pic I posted, the table is clearly visible through the thinner sheets.
So, uh.. I may have went ahead and went with the HAL 9000 mod.. only RGB :D
Edit: here's a YouTube link of it in action.
Basically I put an extra Attiny85 in there, who's sole purpose is to drive a single WS2812B emitter.
It was originally supposed to look like this:
It was great because the positive and negative of the Attiny85 matched the WS2812B perfectly, according to the schematic, which was wrong. The Emitters poles were actually the opposite, so I had to flip or around and run the data line over the back. Much less elegant:
But it worked. I did clean this one up a bit more before installing it, but you get the idea.
The speed of the rainbow effect can be sped or slowed by setting parameters at compile time. There are other effects in the code I found, too.
I have no idea of the current draw, I suspect it is somewhat high, because the Attiny85 is running at 8mhz nonstop to drive the signal fast enough to control the WS2812B, but I don't have anything sensitive enough to measure it.
Very nice! :sunglasses:
Was the schematic wrong or is the chip upside down, reversing the layout?
At any rate, neat idea… I fail to see the reason for it but still it’s out-of-the-box thinking…
The schematic was just wrong, the data in and out pins were in the right place, but the notch in the corner should’ve been positive but it was negative, and negative was positive.
I’m embarrassed to say it took me more than I couple minutes to figure it out. I thought I was damaging them when removing them from the strip I was harvesting the from.
Thanks, yeah I like it. I figured if I was only gonna have one single emitter, then I should do something fancy with it. There’s juuust enough room to get it all in there.
Quite happy with my SST20 3000K. Loving the size and construction.
It’s not too yellow in tint even at 1x7135 and gets better on higher modes when it warms up. Turbo is pretty much perfect.
What is the max Lumens you measured with yours?
I haven’t measured the lumens. My eyes tell me there’s plenty of them though.
:D
If you ever want to measure.. I'm curious to your numbers
It’s not really relevant in FET light like this where all the minute details affect the number.
Well, that is your personal opinion, which is fine. I was just asking.
Once I get D18, you will know some measurement data. I am waiting for the SST-20 4000K version.
+1
Turbo output really depends on a lot of factors, some of which aren’t even part of the light. Basically just think of it as a really bright burst mode, where the actual brightness level doesn’t really matter. It’s like turning on about 10 to 20 common light bulbs all at once, and focusing the light into a beam. But it doesn’t really matter if it’s 10 or 12 or 17 or 20.
It could matter… if’n ya was about to go fishing 20 would bring in more bugs. :wink:
But yeah, mostly that’s true. lol
Very nice HAL 9000 mod!
Looks like there is room at the edges to add 12 more small colored LEDs. Go for it!!! :sunglasses:
Thanks! Lol I actually thought about doing a triple in the middle, but there’s less room than you’d think because each optic has a black holder that goes right to the top under the PCB faceplate thing.
I might try to put one in my D4 though, but I’d have to put the Attiny85 down in the driver space I think? I don’t know I haven’t looked at it.
I’d really like to know how much current is drawing first though
Thanks.. mine is 4000K as well!
