A Q8 with USB charging would make a perfect gift :+1:
But this is in dire need of experts opinion of quality of the changes, for example a “breathing” led button did not seem necessary and may introduce unnoticed problems.
Wellp, it’s got a “breather” sideclicky instead of constant-on like the Q8, and I don’t recall any battery-check option. I found some narsim “cheetsheets”, and yeah, it looks like a PhD dissertation vs the DC7’s manual/options.
Frankly, I managed to get it into stepped modes (vs ramping), and could only manage to go backwards with a long-press. Too short, and it just shuts off (duh). So back to ramping…
Hate “breathers”, so the only other option was to keep the sideclicky turned off. Oh well…
So… quick braindead ramp-up/ramp-down seems fine to me. Shortcuts to lowest/highest are great, too. Probably all the other stuff was edited out for the “simple” version of the UI.
If it’s all freely available in source, wouldn’t it be easier to just pilfer it as a whole, than to try diddling with it trying to copy it one feature at a time?
If they did start with narsim, they might’ve just lopped off parts they didn’t want to bother with, to muggleify it.
Anyhoo, up/down/lowest/highest is fine with me. That’s pretty much all I ever do with my real Q8.
Sounds like they went with one simple mode set rather than the 8-12 or so Narsil supports. It's simpler in that way I guess...
Yes, they did the mimicking in a pretty bad way. Probably used the source code, simplified couple things, maybe ported to a different MCU, not sure.
It's a real, true violation of the principle the source code was released under. I suppose mimicking is honoring, and can't blame them, but they could have thrown us a bone - mentioned it's based on the BLF users, contributions, etc. - even not me personally, but to at least mention our forum...
Funny - Amazon did publish my question, quoted earlier...
This was me: This looks like a sofrn q8 copy, adding charging and slight style changes. why did you copy the sofirn q8?
Don-cha just luv it? We are famous and good enough to be cloned! Wait, didn't we clone the SRK or SupFire M6 with the Q8? Well.........
You know, that's do-able. For that we need direct contact with the fabricators in China, or even elsewhere. But basically, lot of these manufacturers simple contract out the work. You could probably contract out at different levels (full soup to nuts or just parts), different levels of quality too. Of course not many here speak Chinese and have the contacts - this is why you can use a go-between.
Think earlier I here I asked bout the driver, and someone posted the driver pics and appears to be a PIC controller, not ATMEL. Very rare to find ATMEL in production lights. In fact early on in the Q8 development, the ThorFire engineering team decided to implement our UI on a PIC, totally re-wrote our/my provided firmware, and really messed it up. They ended up firing the engineers, started over from scratch with out ATtiny85 and our firmware.
On this one they probably did like a true port of the code to a PIC because they seemed to dupe the UI pretty well.
Five quick clicks of the switch and the breathing switch light is disabled. I am very pleased with the two I purchased. I am also the proud owner of two Q8’s as well. Gotta love the built in charger on the Airpro DC7. I prefer the eye that never sleeps for ease of location in the dark.
