What are you talking about?
Nobody is interested in your experience with 25yo car with engine mechanics that was actually developed in 50-60th. You even wont be able to use this old dirty station in EU and many other countries.
Choose any modern euro-6 engine, and I will try to share some real statistics.
Again, you have no info about output of this 400-500k mileage engines. You just dont care.
More gibberish combined with a bit of “you don’t care” whining garbage topped with more straw arguments.
This has nothing to do with the electric motor then with the life expectancy of batteries.
At this point, they are inferior in life expectancy to any normal car. They may get better, or perhaps not. We’ll see.
“At this point, they are inferior in life expectancy to any normal car.”
“Jay Leno’s 1909 Baker Electric still operates on its original Edison cells, that’s 110years!!”
How much more life expectancy do you require??
No strike that question because I know you will just put some bait answer in.
Bored now…
Toemato Tohmahto. The cheapest I got this year was $1.77/Gal. Thought I had time traveled. I honestly couldn’t care less because I drive like a maniac and my mpg’s are due to suffer.
Me too.
I think Spartan is on the money.
A friend of mine has 3 trucks with over 2 million miles each and they are all running as of today. I don’t think you will get that out of a set of batteries.
I’m not sure that is completely true yet, when you consider power to weight. You also need to consider battery weight with the weight of the motor.
Also, most of the world doesn’t have access to (fish killing ) hydro electricity like Quebec, and uses coal fired generators to produce electricity to charge batteries. So how much does that really help anything.
Engine life, I rebuilt a Ford 300 (4.9) 6 cylinder for a 1980 F100 that lasted 22.5 years before it developed a rod knock and the 2nd auto trans lost 3rd gear. Found a 86 F150 with a four speed manual on the floor to replace it. This truck has same engine (4.9) but has a rod knock so I baby it till I can pull and replace with another I rebuilt for my work van. Been knocking on start up till oil pressure builds up, has been for the last seven years but gets almost 18 MPG, not bad for a 33 year old motor with 240K on the clock. I change oil often, it is the life of the motor. So for me, electric vehicles, nah, I don't think they will last as long.
Anything good about the Audi Etron SUV? I don’t think it is available to buy yet but I saw something about a pre-order option.
Are you able to get new modern and safe car with such motor?
How long youll be able to use your small car until you will catch people from some green political party that have organized miting right in the clouds from gas and oil that have not burned?
I wonder how conservative you are. Your experience is great for people from 50s. But if someone little younger searching car nowadays, he is not able to repeat your experience. They would like something smaller, faster and more safety, than track with tracktor engine. And 99% of cars that meet this conditions have aluminium engine block which can last 150-200k kms.
And this is common at least for last 20 years. I didnt want to leave this comment, but to prevent someone young who will read this thread and was ready to get new MB (and hoping it will last long) - no, they could last long when your grandfather was young.
I like my cars to go vroom. It scares the plebs.
Hows it going back there?
Filling up here in FIN at about 7,82USD/U.S.Gal or 1,83EUR/L
Digging up olds but a few notes on this:
- By default, ICE on a hybrid has same efficiency, as same ICE on a normal car so I agree.
- OTOH, on some hybrids (Or the most, Toyota), they use Atkinsons cycle ICE engines, which have a bit higher efficiency.
They are typically not used in normal cars, at least I don´t personally know a single one that uses. I have HEARD that some London cabs use it but I´m not at all sure.
- One thing that has been also tweaked for lower consumption, is the inf.variable transmission. ICE engine is kept as much as possible on the most efficient RPM range.
Losses on that kind of transmission are actually small. For reference, check WeberAuto on YT. I was surprised a bit about how small amount of parts go in there after all :o
- The other trick made available by electric-everything is, that when you lift gaspedal and COAST (not regenerating), in lower speeds, engine is off. That saves also SOME fuel, depending on where you drive.
(Normal ICE start/stop for traffic lights and such is pretty much in most vehicles today).
- 45mpg I agree on but on my car (old 2010 prius), it means I have to overspeed year round… I hate doing it because penalties here are, hrmmm, “high”. It kind of eats away the benefit of trying to save on gas if I take tickets After 2 years, 45mpg is ± the max that I have gotten out from it. I drive 80% or more highway but speed limits are here 50-62mph. Highest consumption is achieved in winter. Typically at around –4°F or colder.
You guys should not complain. Here in Brasil we’re paying 24$ a gallon of gas. I drive 40km a day to work, and I’m currently spending the equivalent of a month’s minimum wage in gas.
Many people in the US do not recognize that they have very cheap gas compared to what most of the rest of the world pays.
I, for one, am very thankful to only be paying around $3 a gallon currently.
But you have incredibly hot women so it equals out some.
Brazil is king of the corn fields for making fuel for cars. They kinda force all motorist to run flex fuel or full Methanol. Correct?
Yes we’ve been running ethanol on our cars since the 80s. Nowadays 99% of new cars are indeed FlexFuel. However we’re not forced to used it. Our ethanol comes from sugar cane, not corn like US’ E85. However it is almost as expensive as gas. At 19$ a gallon, it is not worth it since ethanol is less efficient than gas thus fuel economy is worse when running ethanol. About 20% less MPG.
Lol! I guess we got that going for us. Which is nice!
