Take that bevel up around another 1\4 in. then grind that shoulder off. Making it even (ish) taper from cutting edge to back of blade
it’s solid enough that if you put a reasonable edge to it.
A good cleaver. chopper. Heavy cutting blade it’ll make.
It’s long enuff, and heavy enuf to do so.
If NOT tip heavy. maybe take a slice off top centre to rear sect of spine
to balance it so.
My Mitchel Engineering (Meatworks commercial supplier here in AUS).
does some similar. Mine. a good. basic steel. Nicely TIP heavy, holds a good sharp edge. and chops through chuck bones like they not there.
And thick. Crusty Dark bread with grains. Like soft butter.
Cost me $11 AUD. now $17 del.
Cheap and nasty but very good 440c steel, (Don’t ever knock it)
It was a top steel for yrs. Still is. Depending who works it.
And professional meatworkers use their steel every day on carcasses
with no problem.
As the steel depends on heat treatment.
The “cutting” edges depend on loong experiences with the stones and steels for best angles. son in law was a pro boner for 40 yrs.
I used to do some boning yrs ago Just to get that experience,
as I was semi-Pro shooting for Roo’s and Buff’s in the top End.
Croc’s (shhhhhh) too. on the side. 6 to 7ft nose to tail got a UNSlitted skin a Grand each Cash… Handbag material. But soooo eay to slice through. as the pressure you had to use to separate skin from fat.
one slice. Value gone.
Shooting those B’s was the best fun though.
Bang. Tween the eye triangle for the brain,
Then blast forward in tinny in dark with grapnels ready.
As the red eye closed and it disappeared in the dark
and the ballast stones they stored in belly took them straight down.
ALl blades. even $3 Chinese “what the F is that” things.
ARE good for something. Utilise it.
Hey Macka17, sorry to hear about your chronic pain woes. Sounds like things are much better now after that spinal implant. But man, must have been tough to get off those opioids. In USA we have a raging epidemic of people getting dangerously hooked on them.
I’m sending Teacher the knife to keep (just minor compensation) so he can play with it and see about improving the edge. I just don’t have that talent (yet…).
Not sure if there’s any rule of thumb about weight, but this one weighs in at 11.75 oz, about 330 gm. The wood is quite decent for the price. I’d have kept it if the blade edge angle was more shallow, so that it would be easier to achieve and maintain a nicely sharp edge.
He’ll probably belt grind it down then reset a cutting angle.
That “shoulder” has to go though.
Regarding the Poppy’s (chuckle)
I’m NOT off them. Just reduced.
Still have a 25/5 Shoulder Fenpatch every 3 days.
$150 ea on open market apparently….
As if I would.
Plus I take a 5mg Targin every Morn.
or a 10mg if going to do some work.
Pre the implant I was on 50+ mg Targin every day. Plus the Fenpatch 25 Patch.
and I carry a card of Endone “lollies”
for the extra sore times.
NOT off. Just reduced, but makes me human….
After 30+ yrs, I’d have to be a “controlled” druggie.
But the specialists that control my input say NOT so…
Who would know hey.
My pain gone 100% most of time.
I’m not gonna whinge about anything.
Just thankful.
Yep, makes sense. It’s on the way to him—he should have it by Friday, I expect.
Yikes, what a cocktail of meds and pain killers. Anyway, what matters most is that most of the pain is under control and rarely felt, so you can live your life! Just sorry you’re having to deal with these outrageous drug prices. It’s criminal… and our government keeps letting us down. Present situation? They’re profiting even more with this administration. That’s cause people like “the turtle” are in bed with them.
Btw, I got that Damascus folder. You were right — very sweet thing for the price! The action seems to be intentionally “notchy”, that I at first thought was grit. But everything is machined well. Seems to be real Damascus type steel. Very, very clean pattern with nice randomness. The rose wood handles are gorgeous. Really can’t beat it.
Just don’t ever use small. Smooth scales/slim blade knives on blood, wet etc. they alright for cleaning nails,
and eating an apple etc.
It’s Ohhhh So easy to slip and slice pinkies real good.
I was a deckie on North Sea Trawlers of NE Coast of UK back in mid ’50’s.
we gutted every cod in those days to get all meat weight in baskets and no offal (better price at quay).
My left coupla pinkies have a few slices in them from when you can’t feel (frozen)and fish slime everywhere.
Over 3 1\2 to 3 3\4in. Go to fixed blade.
And me. over 5in fixed Maartiini. I use a Balanced
Very sharp, hand axe.
Then chainsaw.
Respect your own flesh and bone. They only come around once.
I dropped a 12\14in Redgum once with 6 Brenecke solids from my Remington Pump and coupla doz belts with my axe.
to control fall. Just to experiment.
Tree had to go… Blocking new trail in private forest.
Nice!! But your wallet is now hopelessly screwed christoph…. you have all the symptoms of having been infected with the disease…… :money_mouth_face: :money_mouth_face: …
