Wow, great comparison shot TK! I’m looking forward to getting mine when the time comes. If I can scrape up enough money at the time, I might go for a second one!
also 2. measurement I have overwritten the automatic protocol to charge at 12V to test the plug in to a 12V source as 1:1 car adapter or diretly on a 12V solar panel
I will start now with precise measurements on the BLF lantern
first was that I could see visible brightness changes when doing tint ramping
now also the measurement shows me clearly that ithere is less brightness when between the tints
so there is some work for toykeeper to adjust the tint ramping code,
this was to be expected that some fine tuning is needed
some sort of switch breathing?
current through switch LED shows “heartbeat” pulsing
Thermal test
Setup
room Temperature about 20°C
Maximum current with 7 AMCs
this is a 15min test in timelapse reduced to one minute
the upper part heated up to 41.6°C
30min thermal images
temperature stays on absolutely safe level
permanent LED trimmer added and changed to my 2x2 LKED board with WW LEDs
Things that need to be changed on hardware side
- Programming key viases 0.05mm smaller diameter
- electrical reverse polarity protection of charging circuit and/or mechanical
- switch with warm white LEDs
- added permanent LEDs to switch
- switch wire colors changed to logical colors
black GND (atm LED)
white switch (atm GND)
red Ind. LED (atm switch)
another color for the permanent LEDs
I saw the same thing with the early tests a few months ago, but that was using old XM-L emitters… and those are known to have a slow response curve. So I was waiting for the real prototype before I try to adjust it.
The stair-step pattern is the button’s blinking mode in standby. It loops through a 16-step pattern which looks a bit like a slow heartbeat.
FWIW, the button has 4 modes:
off
low
high
blinking
But what makes me happy is that there are no spikes in the flat zone in the middle of the graph. That means the power use is too low to show up on the scope. It wakes up 8 times per second, so it theoretically could have six spikes in that flat zone, but it doesn’t. So the cost of waking up is indistinguishable from zero.
What it actually does during those brief wakeups is send a “EV_sleep_tick” event through the UI code, which the UI can handle however it wants. In this case, it just updates the button brightness level. Then it goes back to sleep. But this could also be used to implement a timer for a sunrise or alarm clock mode, or to otherwise do things while it’s “off”.
good to hear. :+1: Those are comparable temps i got from the V2 prototype before i resistored the driver back from 2.0 amps draw on maximum, mode after 15 minutes, i got a measured 58 degrees C at the top center of the lantern head with the four 4000K LH351C emitters, then at around 52 degrees with a amp load of 1.65 amps for same duration. ( though its likely this production sample will have better heat dissipation and tolerances for heat transfer from the LED MCPCB to the solid aluminum head.
Lexel, I pieced this post together with data from your post above. I know the test conditions may have been different, but I am guessing he max current you saw with the 7AMCs running was the 2.5A measurement from the video (from some tint ramping testing). Is this correct? Makes sense, 7x0.35A gets pretty close to 2.5A.
Those who don’t want such high levels can disconnect some of the 7135s, It looks like from a picture of the driver board I saw you could (if you wanted) reduce the number of 7135s to only 2. About 5 hours of run time at max with 7 7135s, and 20 hours with 2 7135s on max, assuming 4x3500mAhr batteries. Really looking forward to fooling with one of these when they go on sale. You put so many hooks in place one does not need to be a “modder” to make adjustments here.
