oh I didnt see that
I shine a light at my spinning usb fan to test for pwm. Works well
Is it just me, or is there a face in the water on the right side? Creepy!
There is a face there for sure.
Looks kinda like a caricature of Stan Laurel with his little hat.
Kind of a mirror-image of
Anyhoo, when I put my face close, stare at the image, and kinda go cross-eyed, I kinda see a 3D image of a swan.
The dots in the second picture aren’t necessarily PWM, they just look like the “ripples” in a stream of water reflecting light at different angles to me.
all you have to do is wave your finger back and forth rapidly, in the beam
or point at a rotating ceiling fan
wle
There’s zero chance someone will be able to see 10kHz or faster PWM doing that.
Fast movement of light source - the best PWM test.
maybe but
a. at that frequency, isn;t it imperceptible?
b. would the shower test work for that, assuming PCM/no PCM matters at that frequency?
Ha ha. It was a trick question. She’s not even using a flashlight.
She’s screwing with us… “PWM” are the initials of the person whose face is on the right side
Lol……Selene is playing a game for sure…
I just read her response. Sounds like both are PWM however, just at different frequencies or types….
… (this space intentionally blank, to put the answer at the top of page 2 instead of the bottom of page 1) …
Okay, the poll has been running for a day now. That provides enough results… so here’s the answer.
First, as of this comment, the poll results are:
- A. 65% (39 votes) : Left=PWM, Right=PWM
- B. 10% (6 votes) : Left=PWM, Right=Constant
- C. 17% (10 votes) : Left=Constant, Right=PWM
- D. 8% (5 votes) : Left=Constant, Right=Constant
Total votes: 60
The correct answer is B. The light on the left uses PWM (FW3A), while the light on the right delivers constant current (L3 L10). Both were running at 30 lumens.
There was enough information in the pictures to determine which was which but, just as in real life, it required looking very closely. Click for the zoomed-in picture and look at the narrowest streaks in the middle area of each image. That’s where the visual difference is most apparent.
Of the 60 people who answered, 90% picked a wrong answer:
- 82% had a false positive (thought the right image used PWM)
- 25% had a false negative (thought the left image used constant current)
- 17% got both wrong
- 10% chose the correct answer
The big, bright dotted lines are not PWM. Most of the smaller dotted lines aren’t PWM either. Those are just oscillations in the shape of the water droplets. The water vibrates, spins, or jiggles rapidly as it falls, and this changes how it reflects light. So even a constant current light looks like it has PWM unless you look really closely and are good at interpreting the data.
This is why I don’t recommend the shower test. It’s very error-prone, even among flashlight enthusiasts.
The difference is shown in this little detail section which I cropped out of the full-size image:
Also, in the left image, this part should be a dead give-away for anyone who knows what they’re looking at. It shows a single water droplet oscillating at two different frequencies simultaneously, but… falling water droplets don’t really do that:
As one of the people who was able to correctly tell which was PWM, I think there’s a few things to note - some of them are general remarks, some are comments about the quality of the test or the poll’s evaluation of the test’s quality. In no particular order,
The pwm here is of the faster sort that is not commonly a big problem. Yet close examination does reveal its presence, so it’s at least shown viable even for high frequencies of pwm which may be hard to notice.
The stream of water is one which we could not see with our own eyes, nor in motion or from multiple perspectives, and so we must guess at the speed and character of the water flow. This is true to an extent even in person, since most showerheads do not produce variation-free patterns of water.
It would have made me more sure of what I was seeing if I had a better idea of the specific camera settings and attributes, rather than just knowing the exposures were equal. Not exactly necessary, but while I may reasonably suppose that the iso was higher than the camera is able to be noise-free at, the aperture was opened wide enough that on whatever format this is, at whatever distance this is, the focal plane was a certain depth, and I may assume the exposure time was within a certain range, at least for me knowing as much as possible about the camera’s configuration helps me to subtract out that influence. We did know it was 30 lumens, which was useful to know. All this is partly because you can choose odd settings and get odd results, or choose settings that don’t make things very clear.
The picture quality is deceptive; you don’t realize until you zoom in that there is any more detail to be had - while I’m for the above reasons unable to be certain to the degree I would prefer, I would point to color noise, noise reduction size (likely basic built-in NR rather than purposefully applied) and large areas out of focus as reasons why someone not looking closely wouldn’t realize that within the full-size image are some smaller areas which are in good enough detail to see the fast pwm we’re looking for.
While 50/60Hz or even 100/120Hz flicker (not PWM) of some mains powered lighting allows things to travel fairly large distances between each cycle, the kilohertz scale pwm of a decent flashlight requires you to consider how far something can travel in a fraction of a millisecond, and then zooming in to look at that scale. The larger droplets smooth out the fast pwm so that it can’t be seen, we see only the effect of their changing shape. It is, however, conceivable to me that one might see similar patterns and correctly guess that there was a slower flicker or pwm going on. That gets into where this test isn’t very good; without great confidence in your analysis, you can come up with multiple plausible explanations for what you see, and be unable to choose.
So what we really need is a shower of something less random, like a box of cereal being poured or something.
Hourglass?
I voted left=constant, right=pwm. But I’m really unsure.
yes, same here…
