Thanks djozz for explanation.
Stock is 10511. The others are the same just with different levels of frost.
Just got the light yesterday but am running into an issue. The light switches to moon/low mode after a few seconds of coming on whether it is just on or while I’m ramping. It doesn’t appear to respond consistently to multiple clicks either.
I’ve tightened the tail hard before tightening the head. I’ve also tightened the driver retainer ring. Anything else to check for that could cause this behavior?
its a design “flaw”
Is it stepping down or just going straight to the low/moonlight??
Try calibrating the Temperature sensor & see if that helps.
Has Neal started shipping again? Seeing a lot of orders arriving but I’m sitting on unfulfilled. Shouldn’t have gone for 7A I guess.
That seems to be a plausible explanation for the inconsistency being reported, given how my light wasn’t functioning properly out of the box. I didn’t take it apart and do any cleaning, just loosen/tighten a couple of times… and that probably pushed aside enough thread lube to make a more reliable contact.
Btw, I discovered the split ring holding in the driver wasn’t tightened all the way. I tightened it down a bit (finger tight) and that didn’t change anything, so that’s ruled out.
Thanks for this showcase of the D4 clip. I agree, MUCH more attractive looking. But like you indicated, I also appreciate the slight lip to the stock clip ring. Visually I don’t really notice it, as it’s subtle, but has a tactile presence that helps with grip.
My only complaint with the stock clip so far is that it’s not anywhere close to deep carry. I’m thinking about trying to bend mine into one since its pretty useless to me as-is.
That’s a great detail. Thanks!
Nice! I like that option. Didn’t think to do that. Thanks!
Anyone know how to stop the blinking during ramping? Is it possible?
That setting cannot be changed without some effort.
You’d need to reprogram the driver with your own customized version of Andúril.
Reflashing a driver requires a bit of hardware to connect to your computer and a bit of fiddling with the code.
Check the Link in ToyKeeper’s signature line for more info on reflashing drivers.
Got mine in 13 days. Super happy with the fit, finish, and performance. If you’re still doing the 95 CRI version, count me in.
this blip is normal ? because i get the same thing when i screw the head down.
One alternative to the ‘four click lockout’ would be to use ‘momentary’ mode at a reasonable (non-roasting) brightness.
This would essentially act like lockout, but with momentary access to any brightness you like rather than just moon.
To do this, set the light to your desired output, then turn it off. Click five times to enter ‘momentary’ mode.
NOTE: You’ll need to disconnect power briefly to exit ‘momentary’ mode. Any button presses will just make the light flash. You can’t ramp or enter any other modes while in ‘momentary.’
Just got my FW3A yesterday. Very cool little light. Much to learn on it. I like the candle and lightning modes. Very fun. Quick question: How do I can I easily get to the max regulated mode? I’m not confident I stop right on the blinks while ramping.
I love momentary on but thought Anduril only does that at max ramp.
Do you mean ToyKeeper has already (in this version) updated the firmware to support ‘momentary on’ using the memory mode?
(i don’t have mine to test yet.)
I really wouldn’t trust that. My FW3A and those of many others that have commented here will function normally sometimes after even several full turns of the head depending on how the light is oriented.
Not normally.
The light will not go out if its on.
But will not turn on if its off.
