It is selling well!!!
I just got mine and I’m very impressed. I’m considering the Lumintop FW3A and it’s available in a few different color temps. So, I’ve been trying to figure out what the different temps look like. On this light, the side LEDs are Nichia NCSLE17. From Nichas’s site: product data page the color temp is listed as 3000k. If this is correct, it would place the side LED’s in the WW warm white range, rather than neutral. Is what a warm white LED would look like, similar to the Cree XP-L HI 7A?
Yes similar to Cree 7A tint, just like a halogen bulb light.
Be careful here... The optics/diffusers/etc. makes some big differences. 2700K or 3000K I love for house indoor lighting. 2700K in a flashlight looks dramatically different to me, all depending.
To me there's dramatic differences in LED bulbs and other indoor lighting fixtures vs. our flashlights. In fact I think CREE and others are designing the new LED's more for their fixtures than our flashlights.
Maybe I missed it but are the nichia’s high CRI >90?
Except for the low output it is a decent light no? I can understand that if you’re a lumen junky this light under performs but for me out put is secondary. I’d rather have a stable lightsource and longer runtimes then a lumen monster. I’m kinda on the fence with this one. I’m looking for a nice lantern when backpacking/hammocking and I would only very occasionally use the front light as I mostly use a headlamp when camping.
Any idea about runtimes on the side leds and is the charging circuit decent?
Lumintop calls the side LED's "high CRI", but not sure exactly what - maybe check the datasheet?
It's a real nice light that I'd call high quality, but I consider almost all Lumintops higher quality.
Boy, I didn't check draw on the battery from the side LED's, but they are using a boost driver which should give you decent efficiency across all modes.
I didn't check the charging as well, but Lumintop USB charging in general is done well.
I don’t think there is a single LED especially designed for flashlight use. They are all made for indoor and outdoor lightning, flashlights are a small niche market.
I checked the data sheet (mentioned a few posts above) but 3 leds are listed: 1.7×1.7×0.27 1.7×1.7×0.3 1.7×1.7×0.35 with 4 different Ra listed ranging from 70 to 90 and R9 ranging from not mentionend to 0 to 80. I don’t trust manufactors rating or claims and it’s pretty obvious why not. ( I got high cri nitecore LA 30 that I want to replace with maybe this light. The LA30 cri must be one of the worst lights I have when it comes to color reproduction and color temp, it’s absolutly horrible)
I don’t want to sound like an A-hole but your answer has too many assumptions for me to pull the trigger on a light this expensive, but it is very much apreciated, thank you.
Sorry, I don't have the sort of equipment to measure CRI or analyze the charging circuit.
Well, the XPL HI's look great, and the old XM-L2's and XPL's look wayyyy better than the more modern XP-L2's, for example. Clearly they used to be better in flashlights then they are now.
I think I'll stop answering questions... Thanx!
I’d forgotten about this light. I find it quite appealing.
I think I’ll have to find funds to purchase one.
Any discount codes available?
Martin ran the original deal on it here on BLF, and here, Neal's listing here is pre-order, but the Banggood listing here says out of stock, so I don't know what's going on with it.
For reference, here's another more comprehensive review: https://zeroair.org/2019/04/03/lumintop-edc05c-flashlight-review/
Lumintop’s website says 14500 is included. The pictures on Banggood also say same.
hm zeroair review says,
Could be fantastic if the cell was included!
so which is it ? also its says sold out on banggood whats up ?
I also thought that a battery came with it.
Edit: Neal’s review says battery not included.
From Lumintop website
A Lumintop 3.7V/750mAh 14500 Li-ion battery with anti-reverse, overcharge and over discharge protection is included
Notice: The above approximate parameters are lab-tested with the included Lumintop 3.7V/750mAh 14500 Li-ion battery, it may vary between flashlights, batteries and environments.
The Alli Express ad also says built in battery.
Yes, this is the "official" Lumintop store on Ali, says it's included. I was under the understanding the review samples didn't include it, while in production, it would be included.
It’s too long, the FW3A gets an 18650 in a shorter length.
Why compare an FW3A to an EDC05C?
Two completely different kinds of lights.
You must be thinking of the EDC05.
After seeing the pleasant color of the side LED’s I no longer like cool white LED’s. I think for now on I’m going to only purchase lights in the 4500k - 3300k spectrum. I know the output is usually higher on the CW’s, but colors registers so much better with the warmer light. Are there still a lot out there that like the cool whites?
