Je ne suis pas d'accord! Please don't take this as an offence BlueSwordM but there is no high current reverse clicky switch available that can sustain current drain above 8A without causing a significant increase in resistance in your entire current path. Thus, you lose output over the forward clicky switch. Another side effect is the terrible noise these kind of switches will make when applying too much current. Personally, I prefer the forward clicky with momentary turbo and a locked mode when fully pressing the tailcap switch. I have no problems when people ask for a reverse switch version but I do not agree with the phrase that for the rest of us it is more optimal to use reverse switches. ;-)
In this case, I would prefer the L6 style. Switch is on-off (that is a forward clicky, if I am correct), and an electronic switch for the UI. If there are enough space in the tailcap, they could be next to each other, or if it is possible, the electronic switch could be a ring around the on-off switch.
I am very used to change mode after I have turned on the flashlight, maybe this is why I hate forward clicky.
ToyKeeper already proposed to help but it seems that it has remained dead letter and zero progress was made with Convoy’s flashlights UI, maybe Simon prefer to do things in his own way or maybe it’s because of people continuing to buy his drivers that he doesn’t see the point to improve UI, while better UI would make them even more popular. Bistro UI at least for clicky, please !
