【convoy】H4 and B35AM options are updated
Je ne suis pas d'accord! Please don't take this as an offence BlueSwordM but there is no high current reverse clicky switch available that can sustain current drain above 8A without causing a significant increase in resistance in your entire current path. Thus, you lose output over the forward clicky switch. Another side effect is the terrible noise these kind of switches will make when applying too much current. Personally, I prefer the forward clicky with momentary turbo and a locked mode when fully pressing the tailcap switch. I have no problems when people ask for a reverse switch version but I do not agree with the phrase that for the rest of us it is more optimal to use reverse switches. ;-)
Simon, What about L21A with XHP50.2 ?
In this case, I would prefer the L6 style. Switch is on-off (that is a forward clicky, if I am correct), and an electronic switch for the UI. If there are enough space in the tailcap, they could be next to each other, or if it is possible, the electronic switch could be a ring around the on-off switch.
I am very used to change mode after I have turned on the flashlight, maybe this is why I hate forward clicky.
xhp50.2 can be installed in L21A
Simon could I order M3 with xhp50.2 ?
Hi, what is the difference between the Convoy l21a en m21a?
@Lux-Perpetua, I wasn’t speaking in terms of resistance, but of UI choices.
Most people prefer using reverse switches vs forward switches.
Black Convoy L21A host (L2 21700 version)
Forward switch
Length / Diameter : 179mm / 64.5mm
Weight: 540g
Black Convoy M21A (C8+ 21700 version)
Forward switch
Length / Diameter :155.8mm / 44.5mm
Weight 168g
L21A is significantly bigger and heavier. Bigger reflector, so more throw.
I agreed :slight_smile:
Having the ability to turn off memory mode is very important
Simon, so many new updates!!!. :+1:
Any chance on the 5A bin for XPL-HI S2+ Desert Tan ? :beer:
only XHP70.2
the host is different ,you can distinguish them via photos
sorry ,only got 4C in stock
Simon, could i order L21A with XHP70.2 ?
ToyKeeper already proposed to help but it seems that it has remained dead letter and zero progress was made with Convoy’s flashlights UI, maybe Simon prefer to do things in his own way or maybe it’s because of people continuing to buy his drivers that he doesn’t see the point to improve UI, while better UI would make them even more popular.
Bistro UI at least for clicky, please !
20mm with Anduril and potential for e-switch - sign me the hell up.
See: mtnelectronics’ 20mm FET + 7135. I’d be all over that except shipping from the US is a killer, so if Simon had something similar… :wink:
This is such a pity!
Bistro looks too complicated to me. Also Biscotti has too many options, but I select one mode, store it, and that’s it. Actually I liked the old 3/5 mode driver, except that it generates a squaling tone, which nobody likes. Ideally I’d like to simply have 4 modes 3–35–70–100 no blinking stuff etc.
I like Biscotti too, but wish I could customise the modes that are available to add different levels - I’ll just have to recompile and flash it :slight_smile:
