No worries Simon. It's not your fault but the "others" do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 - 21.7mm). However, a minor increase of the tube's inner diameter might be a nice option for future batches.
The diameter of the (2) Molicel P42A 21700 batteries from Li-ion warehouse wasn’t that large. Granted the spec sheet does say 21.7mm Max.
So for those us with existing drivers that include the bad values in the firmware, it’s just a matter of flashing the latest build from the code repo yes? Or would this require tweaking the fuse values prior to this?
Hi Simon,
Any plans to bring out colored versions of the S21A?
To all others: are you interested in this, and which color(s) do you like most?
My color preference (hi to low): Purple, Red, Green, Gold/Yellow, Blue, Silver, Orange, Cyan.
With metal switch
Concerning body colours:
Urban camo or olive green (natural anodization colour).
I prefer non-reflective rubber caps but metal caps might be a nice option for later modification.
Hi Simon,
With metal switch
I would be interested, but I have a question.
I see the S2+ comes in colors, but it’s only a host. I’ve never taken a flashlight apart before. How easy is this to do to swap the parts into a new color? The LED and circuits scare me a bit. I don’t want to damage anything or break the waterproofing.
Also. Is a metal switch as waterproof as the rubber? What are the pros and cons?
Convoylover:Hi Simon,
With metal switch
S2+ colored is also available as a complete flashlight. Look at Simon’s Convoy flashlight store. Plenty of options. So, if you’re hesitant to do it yourself…
Assembling a host is not difficult if you’re used to holding a soldering iron and know about blue=minus red=plusAlso. Is a metal switch as waterproof as the rubber? What are the pros and cons?
passive101: Convoylover:Hi Simon,
With metal switch
Metal switch is maybe a bit less waterproof, I don’t know. It will stand a few drops of water as long as you stay above sea level :+1:
Convoylover: passive101: Convoylover:Hi Simon,
With metal switch
I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
If it requires soldering I’ll definitely just get a full light. I’ve never soldered anything before.
Is the metal switch just without a rubber cover?
Simon,
I am sure you are pretty busy but I wanted to know if
you were able to fix the driver? ToyKeeper: maukka:Simon, I just received two C8+ with 219C 4000K from you. Please fix the driver on them. Toykeeper will explain what’s wrong.
Maukka measured the PWM speed on each mode:
- 2.25 kHz moon
- 17.9 kHz low
- 36 kHz all other modes
The 36 kHz speed means the driver was flashed with the wrong fuse values.
The 2.25 kHz moon means the driver has a very old version of the firmware on it, from 2016, calibrated for nanjg 105d drivers which were never actually used. This was fixed two years ago, along with some other issues.
If at all possible, I would strongly recommend updating to a newer type of driver, perhaps one with two power channels and an attiny25v or attiny85v chip. This would improve performance and allow for a nicer UI. If not though, it would be a good idea to at least update the firmware on the existing drivers.
I have tried a lot, but it has not been solved yet.
I want to introduce other firmware, such as bistro, crescendo
Simon Mao: Satan@103TFS: Simon Mao: Satan@103TFS:Any one try Lii-40A in 21700 convoy light ,is it fit ?
not suitable
Simon why don’t you make the body of your 21700 a little bit bigger may be 0.5-0.8 mm. to give us more choices of battery ?
cause at first there are only LG SAMSUNG TESLA or SONY 21700 in China , i dont know other brands have a little large diameter ,sorry
No worries Simon. It’s not your fault but the “others” do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 - 21.7mm). However, a minor increase of the tube’s inner diameter might be a nice option for future batches.
yes ,but anyway it’s better to change it to 22mm inner diameter
thanks for your understanding
Hi Simon,
With metal switch
oh ,i think i will launch more color version in the future
is it hard to make different colours?
i also hate black too because all my flashlight are black and it’s boring look.
think i have over 100 flashlights now
Excellent, can’t wait ! :+1:
Simon Mao:I want to introduce other firmware, such as bistro, crescendo
+1
+1 for color variety.
I prefer the dull rough finish in OD green.
It’s easy, but it depends on the market. If producing too much, but the sales are not good, this is very embarrassing.
I bought ready-made orange S2+ couple of months ago, plus the nice tweaking options Simon kindly provides. It has separate page in the store. Red is there too.
Metal switch there has no rubber cover, correct.
passive101:I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
Do you have a link? Does it have the brightest LED option?
I'm not sure that posting such an external links is fine according to rules of this forum. OK, as Simon does that, assuming it's allowed:
Red:
https://www.aliexpress.com/store/product/Convoy-S2-Red-Cree-XML2-U2-1A-EDC-LED-Flashlight-torch-lantern-self-defense-camping-light/330416_32252638688.html
Orange (two pages):
https://www.aliexpress.com/store/product/Convoy-S2-Orange-Cree-XML2-U2-1A-EDC-LED-Flashlight-torch-lantern-self-defense-camping-light/330416_32886884532.html
https://www.aliexpress.com/store/product/orange-S2-flashlight-with-XPL-HI-led-inside-and-ar-coated-glass-biscotti-firmware/330416_32887352316.html
Metal button on the photo looks exactly like mine.
As for LEDs, I took Biscotti *8 option — is it the case? It should be also possible to order it with SST40, I think. Anyway, you may just ask Simon a question about an absent combination, this option is very cool feature of the brand :)
