passive101: Convoylover:Hi Simon,
Any plans to bring out colored versions of the S21A?
To all others: are you interested in this, and which color(s) do you like most?
My color preference (hi to low): Purple, Red, Green, Gold/Yellow, Blue, Silver, Orange, Cyan.
With metal switch
I would be interested, but I have a question.
I see the S2+ comes in colors, but it’s only a host. I’ve never taken a flashlight apart before. How easy is this to do to swap the parts into a new color? The LED and circuits scare me a bit. I don’t want to damage anything or break the waterproofing.
Also. Is a metal switch as waterproof as the rubber? What are the pros and cons?
S2+ colored is also available as a complete flashlight. Look at Simon’s Convoy flashlight store. Plenty of options. So, if you’re hesitant to do it yourself…
Assembling a host is not difficult if you’re used to holding a soldering iron and know about blue=minus red=plus
Metal switch is maybe a bit less waterproof, I don’t know. It will stand a few drops of water as long as you stay above sea level :+1:
Convoylover: passive101: Convoylover:Hi Simon,
With metal switch
I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
If it requires soldering I’ll definitely just get a full light. I’ve never soldered anything before.
Is the metal switch just without a rubber cover?
Simon,
I am sure you are pretty busy but I wanted to know if
you were able to fix the driver? ToyKeeper: maukka:Simon, I just received two C8+ with 219C 4000K from you. Please fix the driver on them. Toykeeper will explain what’s wrong.
Maukka measured the PWM speed on each mode:
- 2.25 kHz moon
- 17.9 kHz low
- 36 kHz all other modes
The 36 kHz speed means the driver was flashed with the wrong fuse values.
The 2.25 kHz moon means the driver has a very old version of the firmware on it, from 2016, calibrated for nanjg 105d drivers which were never actually used. This was fixed two years ago, along with some other issues.
If at all possible, I would strongly recommend updating to a newer type of driver, perhaps one with two power channels and an attiny25v or attiny85v chip. This would improve performance and allow for a nicer UI. If not though, it would be a good idea to at least update the firmware on the existing drivers.
I have tried a lot, but it has not been solved yet.
I want to introduce other firmware, such as bistro, crescendo
Simon Mao: Satan@103TFS: Simon Mao: Satan@103TFS:Any one try Lii-40A in 21700 convoy light ,is it fit ?
not suitable
Simon why don’t you make the body of your 21700 a little bit bigger may be 0.5-0.8 mm. to give us more choices of battery ?
cause at first there are only LG SAMSUNG TESLA or SONY 21700 in China , i dont know other brands have a little large diameter ,sorry
No worries Simon. It’s not your fault but the “others” do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 - 21.7mm). However, a minor increase of the tube’s inner diameter might be a nice option for future batches.
yes ,but anyway it’s better to change it to 22mm inner diameter
thanks for your understanding
Hi Simon,
With metal switch
oh ,i think i will launch more color version in the future
is it hard to make different colours?
i also hate black too because all my flashlight are black and it’s boring look.
think i have over 100 flashlights now
Excellent, can’t wait ! :+1:
Simon Mao:I want to introduce other firmware, such as bistro, crescendo
+1
+1 for color variety.
I prefer the dull rough finish in OD green.
It’s easy, but it depends on the market. If producing too much, but the sales are not good, this is very embarrassing.
I bought ready-made orange S2+ couple of months ago, plus the nice tweaking options Simon kindly provides. It has separate page in the store. Red is there too.
Metal switch there has no rubber cover, correct.
passive101:I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
Do you have a link? Does it have the brightest LED option?
I'm not sure that posting such an external links is fine according to rules of this forum. OK, as Simon does that, assuming it's allowed:
Red:
https://www.aliexpress.com/store/product/Convoy-S2-Red-Cree-XML2-U2-1A-EDC-LED-Flashlight-torch-lantern-self-defense-camping-light/330416_32252638688.html
Orange (two pages):
https://www.aliexpress.com/store/product/Convoy-S2-Orange-Cree-XML2-U2-1A-EDC-LED-Flashlight-torch-lantern-self-defense-camping-light/330416_32886884532.html
https://www.aliexpress.com/store/product/orange-S2-flashlight-with-XPL-HI-led-inside-and-ar-coated-glass-biscotti-firmware/330416_32887352316.html
Metal button on the photo looks exactly like mine.
As for LEDs, I took Biscotti *8 option — is it the case? It should be also possible to order it with SST40, I think. Anyway, you may just ask Simon a question about an absent combination, this option is very cool feature of the brand :)
passive101:
I’m not sure that posting such an external links is fine according to rules of this forum. OK, as Simon does that, assuming it’s allowed:
Red:
Orange (two pages):
Thanks!
passive101:
There's no restrictions on links as long as it's good intent, just follow the rules: http://budgetlightforum.com/forum/misc/siterules.
Frequently I see posts where links are avoided and wonder why? When it's a helpful link on info, deal or to just buy something, it's all good for everyone.
If you get the driver with Biscotti and an SST40, it won’t be the brightest - there’s a 5A drivers that’ll run it far harder than the Biscotti driver but without a nice UI.
That said, you’re gonna find your hand awfully warm running 5A in the S2+ at 100%
Thanks!
You are welcome.
Just in case: that orange color is not an “acid orange” like orange fruit or carrot inside. It is darker a bit, still nice for me, but harder to describe. Red might be the same, I think - not the brightest and most shiny tone.
Frequently I see posts where links are avoided and wonder why? When it’s a helpful link on info, deal or to just buy something, it’s all good for everyone.
Thanks for the link.
As for reasons, I agree, just saw forums which prohibit (any?) links because of advertisement, fraud or malware reasons. Sometimes there are intents like blocking other platforms for communication to keep audience at themselves. Even saw forums which add account restrictions after sending links in private messages.
Simon, do you have the M3 with SSt-20 or 40 in cool white?
Sorry ,no corresponding driver.
