【convoy】convoylight.com ( Credit card payment is available )
@Simon - the XHP35 driver is a 1C boost driver or multi-cell?
Driving the XHP35 HI at 2.3A is very good. All the other single cell 12V output boost drivers I’ve seen have been about 1.5A max. Very much looking forward to this driver. I’m currently waiting on my first L21A to arrive and I’ll order a second for the XHP35 HI when it’s released.
For what it’s worth, I would prefer a 5000K or 5700K XHP35 HI over 4000K. I tend to find 4000K a bit too warm for a thrower but find the 5700K in my ThruNite TN42 just perfect. Either way, it will be excellent. Keep up the great work, Simon :+1: .
Very good news, Simon :partying_face:
Another question: does L21A support all common 21700 cell sizes (the thicker ones as well), or just a few selected ones?
(I am looking for higher CRI XHP35 HI, and I will definitely try a L21A build with it)
Simon, you are awesome. Behaving like a Santa Claus - making all BLFers wishes come true. Incredible.
What’s gonna be next? How about adopting E21A?
Thank you Simon, this is great news. This is why Convoy is my go-to brand, I always recommend your shop to people I know.
A heat resistant 7mm outer diameter circular gasket for E21A would be awesome (it should have approximately 3mm inner diameter, and the hole should be circular, as phosphorus layer on E21A is rather sensitive to mechanical stress, while gasket is rotated during assembling). Once this is completed, that would support many builds - currently no one did this for us yet.
E21A is currently the best high CRI emitter for flashlights - a bit lower powered, than SST-20 high CRI (only about max. 2A per emitter), but the offered CCT range is unmatched by concurrent offerings :smiley:
Hi Simon,
Do you have or plan any flashlight able to use all of AA / NiMH / 14500 li-ion (voltage range 0.8…4.4V)?
Interested in both one and two cell variants.
Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
BTW, is the Bluish Gray actually a different color than the standard Gray Convoys come in? Thanks!
Are the XHP35 drivers going to be sold at the Convoy Flashlight store in the near future? I’m guessing a 17mm board would be too small to adapt the items required for that driver?
Hey Simon. Can you offer the M21A with a good 21700 battery? I can’t find them anywhere that ships to my country.
pity that only support LG SONY TESLA SAMSUNG 21700 (DIAMETER LESS THAN 21.5MM)
i will get AA/14500 driver with high efficiency soon ,one or two weeks
What is the most reasonable mode ?
15%off
there is no code
submit your order ,then close the payment ,and last you leave a message to change the amount
factory will produce normal gray in the next batch
22mm ,friend,17mm is too small
i will get some LG SONY SAMSUNG 21700 in stock soon
Nice! Will definitely buy some.
Is the new L2 21700 XHP35 driver compatible with the original 26650 L2 design? Will it fit?
I think the answer is no. But checking anyways.
Thanks.
Hello Simon,
do you have any 3V driver with 22mm diameter and for reverse clicky?
Which adapters do you have for 22mm drivers?
I would be interested in such driver, if it is compatible with the T2 host, and has faster PWM than the T2.
