【convoy】H4 and B35AM options are updated
Simon, you are awesome. Behaving like a Santa Claus - making all BLFers wishes come true. Incredible.
What’s gonna be next? How about adopting E21A?
Thank you Simon, this is great news. This is why Convoy is my go-to brand, I always recommend your shop to people I know.
A heat resistant 7mm outer diameter circular gasket for E21A would be awesome (it should have approximately 3mm inner diameter, and the hole should be circular, as phosphorus layer on E21A is rather sensitive to mechanical stress, while gasket is rotated during assembling). Once this is completed, that would support many builds - currently no one did this for us yet.
E21A is currently the best high CRI emitter for flashlights - a bit lower powered, than SST-20 high CRI (only about max. 2A per emitter), but the offered CCT range is unmatched by concurrent offerings :smiley:
Hi Simon,
Do you have or plan any flashlight able to use all of AA / NiMH / 14500 li-ion (voltage range 0.8…4.4V)?
Interested in both one and two cell variants.
Hey Simon, any chance you have a Code for the “Bluish Gray” S11 on AliExpress? I assume that is from your store.
BTW, is the Bluish Gray actually a different color than the standard Gray Convoys come in? Thanks!
Are the XHP35 drivers going to be sold at the Convoy Flashlight store in the near future? I’m guessing a 17mm board would be too small to adapt the items required for that driver?
Hey Simon. Can you offer the M21A with a good 21700 battery? I can’t find them anywhere that ships to my country.
pity that only support LG SONY TESLA SAMSUNG 21700 (DIAMETER LESS THAN 21.5MM)
i will get AA/14500 driver with high efficiency soon ,one or two weeks
What is the most reasonable mode ?
15%off
there is no code
submit your order ,then close the payment ,and last you leave a message to change the amount
factory will produce normal gray in the next batch
22mm ,friend,17mm is too small
i will get some LG SONY SAMSUNG 21700 in stock soon
Nice! Will definitely buy some.
Is the new L2 21700 XHP35 driver compatible with the original 26650 L2 design? Will it fit?
I think the answer is no. But checking anyways.
Thanks.
Hello Simon,
do you have any 3V driver with 22mm diameter and for reverse clicky?
Which adapters do you have for 22mm drivers?
I would be interested in such driver, if it is compatible with the T2 host, and has faster PWM than the T2.
Do you mean, if I like colors for other models?
Which models do you recommend?
My favorite is S2+ and the only 18650 model in colors. C8 has some color too but same firmware issue. Let me know what do you recommend :heart_eyes:
Moonlight, low, medium, high. No strobe of any kind. Always starts in moonlight. No PWM.
Thanks Simon! Order placed with note yesterday. Kind of curious what this Bluish Gray is going to look like. Then I noticed a Pastel Blue on sale this weekend but the pics seemed to be the standard gray. So wondering what Pastel Blue looks like.
Also, is that you selling through Banggood? Just received 2 S2+’s and 2 S11’s. One of the S11’s shows signs of being dropped and it doesn’t work. Switched bodies around between the working one and the broken one and it’s definitely something in the head. The two wires suppling the emitter are fine so it’s something farther inside the pill but I’m not interested in going any farther.
Emailed Banggood about a refund on the broken light. So you might see that. Thanks!
I prefer memory mode. Switch on where I left it. PWM is ok if it is fast enough (S2, C8)
Strobe can stay if it is hard to initiate. E.g.: Lumintop Tool AA 2.0: click 6 times quickly to start strobe.
