Emisar D4v2 leaked
Please be 18650, 21700 lights are bulky
Seeing that the same light can have different aux colors it looks like they are selectable via the config UI? - like the aux board has red green and blue leds that can be conbined?
NO!
even if the driver MCU had enough pins to control this, there is not enough space to route RGB LEDs on a 2 layer board, those LEDs are also too big
and Hank doesnot want any complicated Aux boards
I never had an Emisar but if the spring isn’t very thight with an 18650, a 21700 may fit lenghtwise.
The diameter likely is a far greater problem.
all Emisar lights never worked with protected cells,
stop guessing and dreaming and keep to the known facts
That’s exactly what I do.
Unlike you: “21350”
So read, instead of rant.
IMO D4 should remain 18650, and D4S/D1/D1S should get 21700 tube makes more sense due to head size
Cyan color please
the ss bezel looks really cool.
The gold ano should had been some darker gold, like a mix of copper-gold ano. Maybe a little bit more dim than this example.
shame no lighted switch, they could have done like ff e07 match aux leds with switch color too, that would look even better.
Looks interesting. I hope it has a configurable ramp ceiling.
I agree with you, that a lit switch would look cool. . However, I think a recessed switch, something the E07 and the present D4 lacks, somewhat makes up for the switch not being illuminated. It makes it easy to find the switch and makes it less likely to be accidentally switched on in your pocket, should you forget to lock it out.
I second the motion.
Looks like a “must-buy”. Hope it comes with Anduril.
Hoping for more 7135’s in the driver - that would be awesome.
This is the one thing that would entice me to buy more D4’s. My current D4’s don’t get used much, primarily because I prefer regulated output.
If the new D4 has higher regulated output and Anduril, I guess I could stop worrying about the FW3A optic debacle.
FW3A optic debacle? Maybe I shouldn’t ask… Really enjoying my FW3A…
Start here: FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #11823 by Neal
Not a problem unless you’re planning to order more, though.
