Here’s what was on the floor (it fell from one of the perspex side tables).
It could have struck the steel bezel on the Q8. The lamp base is white plastic, so not to blame. The Q8 doesn’t have a scratch, so score one for the Q8, one down for the FW3A…
Strange, I can’t see either of fazalmajid’s images.
I know the problem is on my end because you all are referring to what you see. But I have no idea what the problem is….
I’m on my phone but I never have a problem seeing pictures. It’s got me stumped….
Edit to add…. I “never” have a problem unless some other people do also…. as RC mentioned below above.
I can’t even quote the post & see them.
Would some kind soul repost them so I can see if that makes a difference.
Agreed, the stainless bezel of the Q8 is the most likely suspect. In fact it is really the only suspect really besides the edge of the lamp stand base.
I’d say the bright side is that the ano is adhered so well that it had to be scraped off from the looks of it. I’ve seen ano chip off in chunks when done poorly.
That’s just a reflection on the aluminum (probably the FW3A box). It’s hard to shoot something that reflective.
Here are some shots with a macro lens, varying the position of the light source.
The lamp is an IKEA “Not” uplighter. Given IKEA quality, I suspect dropping popcorn on the lamp would dent it The lamp base is completely covered by the white plastic shield, there’s no way the FW3A would have banged against it.
Agreed about the Q8 bezel. I had forgotten about it when I first posted. I would think a type III hard anodized surface would have bounced without too much damage. I tested that theory with a $15 UltraFire WF-502B red LED light I have lying around. I dropped it on the Q8 bezel from slightly higher than the FW3A dropped, and neither light suffered any damage.
As for the people who are having problems loading the images, I apologize, they are hosted on my own site, which has ultra-paranoid HTTPS/TLS security settings, so if you have an older browser or operating system it may not be able to negotiate. The images are on: Index of /images/blf/
