Which mode sequence you prefer
41 posts / 0 new
SKILHUNT
SKILHUNT's picture
Last seen: 1 week 11 hours ago
Low> Med> Hi >Turbo > Hi > Med > Low
13% (15 votes)
Low> Med> Hi >Turbo >Low> Med> Hi >Turbo
65% (77 votes)
Double click L1<=> L2 , M1<=> M2, H1<=>H2, T1<=> T2, one click L>M>H>T , (with sub modes)
9% (11 votes)
Double click T>H>M>L, one click L>M>H>T (No sub modes)
13% (16 votes)
Total votes: 119
Edited by: SKILHUNT on 07/29/2019 - 22:11
lionheart_2281
lionheart_2281's picture
Last seen: 13 hours 45 min ago
Next mode memory Wink Big Smile
djozz
djozz's picture
Last seen: 18 hours 44 min ago
Voted!
1stein
1stein's picture
Last seen: 1 hour 15 min ago
There was once Convoy’s driver with setup: 1-click, 2-click, 3-click, you could program two firsts light power and third one allowed for some blinkies or moon.
I don’t know why this soution did not spread wider. IMHO: a great solution, you can easily access any of modes you desire without going the “clicky-path”. And I realized that very rarely I need more than 3 modes.
Don’t you think that n-click based driver would be nice? Even going to 5-clicks you can access any of modes right away.
varbos
Last seen: 3 days 18 hours ago
In a stepped light I prefer L-M-H-T-L-M-H-T
The reason for this is simple: I know what will happen when I click the button. It is always the same.
“Wave pattern” in a 3-level light is slightly annoying (L-M-H-M-L).
“Wave pattern” in a 4-level light is very annoying (L-M-H-T-H-M-L).
Agro
Agro's picture
Last seen: 2 min 10 sec ago
Definitely L-M-H-T-L-M-H-T.
BUT:
  • I highly value lights that always start low, my memory is consistently shorter than that of my flashlights and with mode memory I never know what level will the light have once I turn it on
    • I actually also like lights that consistently start at a medium / medium low level as well, as long as they have a shortcut that enables me to turn them on at low / moonlight
  • I highly value lights when I can always go from M to L without passing H or T and blinding everyone around (myself included).
Unheard
Unheard's picture
Last seen: 19 min 37 sec ago
Triangle instead of sawtooth.
Problem is: You never know what the next mode would be if current mode and direction are memorized (by f/l, not by human brain).
Smile, you cannot kill them all.
hodor
hodor's picture
Last seen: 3 days 19 hours ago
BUT:
Shortcuts to moon and turbo FTW Thumbs Up
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 15 hours 56 min ago
L-M-H-T with memory mode.
MascaratumB
MascaratumB's picture
Last seen: 4 hours 14 min ago
Voted “Low> Med> Hi >Turbo >Low> Med> Hi >Turbo”!
Ideally, the possibility to go UP and DOWN on modes (ramping style) would be nice. But normally I prefer the above mentioned sequence. Actually, I did not buy some lights from a certain brand [despite I like their designs a lot!] because of the L-M-H-T-H-M-L sequence Oops
Tally-ho
Tally-ho's picture
Programmable UI like Bistro that let you choose modes order, low to high or high to low, let you choose numbers of modes, enable or disable memory, etc.
L M H T H M L is terrible for me.
1332332331
Last seen: 11 months 1 day ago
Mode memory is fine, as long as there is a shortcut from off to low. (I like a shortcut to turbo too, but it’s not as important.)
Boaz
Boaz's picture
Last seen: 1 hour 36 min ago
Really irritating to not know whether the next click will be brighter or dimmer . You're wrong 50%  of the time  So half the time the light is a disappointment .
varbos
Also, very important that location beacon (flashing red light on button) has much lower drain in future Skilhunt flashlights.
On H03 the drain is like 2mA
Unheard
Unheard's picture
BTW, Andúril ist very good at that. Click and hold for up, Doubleclick and hold for down. Best method when being limited to a single button UI imo.
Henk4U2
Henk4U2's picture
Last seen: 18 min 43 sec ago
Sawtooth for me!
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
PBWilson
Last seen: 17 hours 40 min ago
Out of those two, I prefer LMHTLMHT. It’s easier and quicker to get back to a low setting and as it was said before, you don’t know if the light is going to get brighter or dimmer when you pick it up.
With a stepped mode light, I would prefer Hold from off to get Moon, hold to scroll through LMHLMH, double click to Turbo whether on or off and a single press to turn it off. That would suit me just fine.
Deputy Dog
Deputy Dog's picture
Last seen: 6 months 1 week ago
T-S-H-M-L
DavidEF
DavidEF's picture
Last seen: 2 weeks 2 days ago
I know the poll is pretty much decided for at least the few of us that voted, but I’d like to see more votes here, so…
BUMP!
BTW, I voted L>M>H>T>L>M>H>T and I prefer also the following:
  • Last mode memory
  • Direct from off to lowest mode (Moonlight if it is available, or low)
  • Direct from off to Turbo
- The YKK Philosophy
shirnask
shirnask's picture
Last seen: 7 hours 28 min ago
I voted L>M>H>T>L>M>H>T Direct from off to lowest mode Don’t care about memory
avservice
Last seen: 2 years 2 months ago
I have grown to LOVE the ZL UI and the newest version lets you set it up almost any way that I prefer…….twice!
Of the 2 options in the top of this thread I would choose the 2nd one.
Yokiamy
Yokiamy's picture
Last seen: 27 min 59 sec ago
Bistro or blf A6 UI; short press forward, medium press backward/reverse, so you can toggle to high and press some longer to go back to medium for instance.
SKILHUNT
SKILHUNT's picture
Thank you very much for your votes and comments!! Thumbs Up
Now I just added two more choices,
1. with sub-levels, so one click is L>M>H>T>L>M>H>T, double click is L1<=> L2 , M1<=> M2, H1<=>H2, T1<=> T2
2.Don’t need sub-levels, so one click is L>M>H>T>L>M>H>T, double click is T>H>M>L>T>H>M>L
Which one you prefer? After votes, then we will change our mode setting in future design. Thank you very much for all your comments and votes again~~!!
Macka17
Last seen: 11 months 3 days ago
2 cycles.
L.M.H.
With long click to bring in Quick Flash then Intermittent,
for annoying people..
ALWAYS start on the low.
I reckon As soon as you bring in Turbo, you overloading .
Both the battery and system.
Better off pulling that stronger torch out of other pocket hey.
It only lasts for a short while anyway.
Then most drop down automatically.
flightless22
flightless22's picture
Last seen: 11 hours 10 min ago
Uh… the poll will now be skewed since you added new options after votes have already came in Facepalm
I really like the UI of the H03, the hidden sub-levels is absolutely preferable over the second option.
Ryzbor
Ryzbor's picture
Last seen: 2 weeks 4 days ago
And it is muggle friendly.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
wle
wle's picture
Last seen: 12 hours 30 min ago
anduril ramping is the best
followed by astrolux s1 :
8 steps, fast clicks go up, slow clicks go down, from turbo it goes back to moon
also with selectable mode memory, you can have it on or off
after that would be anything that goes up to max, then to minimum
NOT L-M-H-M-L
terrible
i can think of worse – BLECH – than that but i just ate
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
808080
Last seen: 2 years 5 months ago
I’d like like the option for no memory (always start low) – the flashlight may remember the last mode but I almost never do!
Barkuti
Barkuti's picture
Last seen: 20 hours 48 min ago
WTFITS?
Hi - Low - Strobe for the win! Big Smile
Smile
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Nev
I haven’t voted ,
My choice would be to leave it as it is ,it works fine why change it ? People who already have a skilhunt light know how it works , it works well , why have another skilhunt torch in your armoury with a different ui?
It gets confusing.
Xoden
Last seen: 1 year 6 months ago
Short click to ON(Low)/OFF;
Hold from off to Moon,
Hold from Moon to Low, then cycle L>M>H>L>M>… (and maybe long click to cycle backwards)
Double click (both from off and on) to Turbo, only access Turbo through double click.
No memory.
This way it’s predictable, can be turned on by anyone, with only three modes in the main sequence and the other two still easily accessible, but without getting in the way. And even if you hands are too frozen to properly click, you can at least press and hold to get some random level of light.
