Some more experience with the light string.
2 more trips, it survives folding so far.
I love how cosy it is with the light on, I’m way more satisfied than I thought I would be.
I so wish that the powerbank and the string used Type C connector.
Now I have a power bank - Micro USB - converter - Type A - string. And having to orient both MicroUSB and Type A correctly is annoying.
I may switch to another converter, one that makes it impossible to plug wrong. It will make things slightly easier.
Got one issue though, I got a single dark night where the string wouldn’t turn on.
I was too tired to troubleshoot and the next day it was OK.
Some connectivity issus (I tried reconnecting several times)?
Some weird quirk of my Folomov flashlight-powerbank?
I don’t know, I need to troubleshoot it the next time it happens.
Go to Customer Reviews. The 2nd one is from a fellow in Russia who was unsatisfied and soldered in his own LED’s. Red is kind of useless for a light such as this, as it’s not all that useful as an emergency beacon. So he swapped in warm white LED’s. Looks really nice now. Wish he had a better write-up on it!
I have a couple of the Soshine CB2 versions of that light you pictured, (I also have a couple of that same AAA-powered version) its a rechargeable 1800mAh Lithium Ion powered version. (built in USB micro charging, warm-white LED tint, AliExpress seems to be the only place i seen them. They work ok, small compact, lightweight, couple hours run time on high, around 200 lumens, down shining & ideal for hanging in a tent. https://www.aliexpress.com/item/32814866531.html?spm=a2g0s.9042311.0.0.188b4c4dKyUW3K
Two Fenix CL25R’s, one inside the tent, and the other in red mode. Zanflare T1 on low. I leave the red on all night outside. Works as a night light and doesn’t attract bugs.
No kidding? Dang. I’ve had one of these and got rid of it because step-thru UI was tiresome and basically forced you to use the light since it just blinded you. Had red though. https://www.fasttech.com/products/3720601
Also had ordered this one, great battery life, USB recharge, no PWM, tiny, but does have the step-thru UI so cover it up for the first 3 clicks. Kept it because of size and battery life. https://www.fasttech.com/p/3720501 D’oh!
I guess the mosquitoes will find me even in the dark but if red will keep away the dorks of the bug world, the Junebug, then I’m all in.
Fixed. Sorry. The one in the fixed link has magnetic back also.
It’s a first-world-problem but a bad UI just kills a light for me. I’d pay 50% more for any light or lantern with a UI that doesn’t ruin the experience. Long press for low, no forced blinkies, no more than one click for off. I don’t think they use their lights. None of this will matter soon when the LT1 ships (woo!) but perhaps a small BLF micro-lantern would fill a niche?
Actually a VERY good little lantern… I use mine for Camping, Caving, Warning light at night walking alone a road, General reading light and so much more…
Lights up a room Very well indeed, same goes for a 10 man tent! Great in medium sized carverns when caving and fantstic in small ones…. Just a nive EXTREMELY pocketable lantern….
Yeah, looks nice, thank you for the suggestion.
But as of now I’m looking to get another 10m string, for the vestibule. Though I could really use something with regulated brightness there…
Those look really cool. I was not aware there were so many different nice lantern designs out there.
Candle has caught my attention.
Though I’m not a fan of solar charging due to the fact that I often leave my tent unattended. I don’t want to leave the items that need charging exposed and if I don’t do that they won’t have much charging time.
Some Luci lights come with USB charging (2-way, those who like solar can collect some energy to power other devices) - but candle doesn’t.
Also, candle outputs mere 25 lm. Enough for a mood light but not for a general purpose. Luci Pro Outdoor 2.0 looks better for me, though it doesn’t have a candle mode. And it doesn’t have CCT specced.
I just came back from Bratislava and Mosonmagyaróvár - I used a Folomov EDC C4 with my favourite (Naturehike) diffuser. My wife complained that mood-wise it was way worse than a LED string….
I still need a light for the vestibule of my villa. And another for my smaller tent. I have a feeling that after some trials (LT1 needs checking) I’ll end up with light strings in both.
In my medium sized tent I keep banging my head against it. Extremely annoying with anything but AAA.
The diffuser sometimes falls off when I bang my head against it
With significant amount of light it’s blinding despite the diffuser
It directs most of the light straight down. Very little reaches the far end where I have my backpack.
I want my tent light warmer and higher CRI than my walking light
Bouncing light off the top of the tent turned out better but I still wished for something better.
A string light doesn’t most of these drawbacks and creates extremely cosy atmosphere. Gets me and my wife in a really good mood.
Though it is single mode though and has low CRI - I’m trying to deal with both issues.
Maybe not what you’re looking for but this diffuser/case coupled with a nice headlamp (can also work with flashlights) works well for tent lighting. It has a reflective cone inside which directs light sideways. It’s also quite secure if you tighten the drawstrings. I have the small one as carry case and diffuser for my shorty h03 with 2700K SST20 and anduril headlamp. I leave it at lowest level candlelight mode or moonlight mode so it’s easy to see when I wake up at night. Candlelight mode will also get anyone in a really good mood. I know my girlfriend loves it.
