I Have a MNKE 26650 400mah that I overdischarge up to 1.8v and wont charge in my other charger except on my ML-102 V2, After a few hours its now full charged to 4.2v.
Do I have to worry about anything that happened to this battery?
Thanks
Thanks
Many charger cannot pick up a cell with a voltage lower than 2.2V, so I think it's normal that most chargers won't charge this cell.
What cause this over-dischage, was it a boost driver? Under load the voltage must have been lower than 1.8V.
Actually an error on my part, Used this to power my 2xD operated Fan and forgot to turn it off, The Fan stopped working and when I checked the voltage its at 1.8v. I used a stock driver from one of my lights thinking this could act as my over discharge protection circuit but I made a mistake almost causing killing a barely used battery. Currently using a protected 18650 batts in the Fan.
First post here guys. Newbie to this new world (but not to the interest :) ).
Just ordered the King Kong INR26650E. N.Shock or someone, any chance you can do a discharge test on these to compare to the ICR?
Bose301s, go Huskys :) 2002 Graduate
Don't be surprised when you actually get them, that it really is a King Kong ICR26650E
yeah, hoping not the case.. Ordered from the CN Quality Goods link at top of page.. but we'll see... 20-30 days out lol.
I don't want to wait anymore :( want king kongs and tr-j12 now.. please?
Agreed, but I did contact Ric @ CNQG and he assured me he has both and changed the website to reflect that. Let us know what you end up receiving.
And 01110111011001010110110001100011011011110110110101100101 to BLF, binaryman!
Thanks :) Here's to hoping..
Found some discharge graphs to compare to N.Shock's ICR.. no time on these graphs though, but if converting correctly looks like a bit more run time.. Either way looks good:
Can anyone say what size magnets (or better yet link, or ebay link) I might need to get my kingkongs to work in my TrustFire tr-j12?
It's good to have you here, binaryman.
Did you know that there are only 10 types of people in the world: those who understand binary, and those who don't.
The little rare earth magnets work perfectly. You can order from overseas or get them from Harbor Freight, 10 pack for $1.89:
http://www.harborfreight.com/10-piece-rare-earth-magnets-67488.html
Ok. I wasn't sure, as I read neodymium doesn't conduct 'as well' as other metals/magnets, didn't want a current issue.
Also, better to get smaller diameter ones, or like 25mm so can tape in place easier? What's best way to keep them from moving around with a bump?
I don't own any INR26650E. So no comparison from my side. Sorry!
Sorry forgot it, but I won't use magnets between 26650s
You know, I'm not sure on that. I only use the magnets for charging purposes, but I read somewhere that IOS shipped their JM05 / King Kong combo with extra magnets - here's a picture from Foy's review:
These look wider and flatter than the rare earth ones I recommended. However, I can tell you that the r.e. ones are pretty hard to move; I can't remove it from my battery without using needle nose pliers.
I'm using these ones and they are very strong and work great with the King Kongs & my TR-J12..................I also put tape around the batteries to prevent the magnet from any jars that may occur......doubtful, but better safe than sorry.
http://www.dealextreme.com/p/super-strong-rare-earth-re-magnets-8mm-20-pack-4248
Sorry, but that looks dangerous as all hell.....you don't need a magnet on the end battery for the tailcap........at least I never have. For the TR-J12 I put 3 King Kongs together and placed a 8mm x 1mm magnet in between the 3 cells, thus I only need 2 magnets and tape those 2 joints.
Thanks guys for all the great info! You guys are awesome :)
Just got my battery space LiNiCoMn cells...
Deans connector an springless charge cradle
Out of the box cells were ~3.7V
Current climbed up to 2A, where I have it set to max to keep C<1. Waiting for Vbatt to climb....
Heres something strange... Charger tops out at 4.2V like it should (which seems suspicious so early on in the charge cycle), but my Fluke only reads 3.97V. Anyone know whats going on here? Its never done this before with Panasonic 18650 cells. Usually the charger is a little off from the meter... but not way off. **EDIT** just figured it out... loose contact between the meter and cell. fixed without incident.
It looks like a mystery..............sorry couldnt resist.
