The driver works great but I noticed it goes into emergency low mode(flashlight dims and flashes very slowly) pretty quickly so, I checked my battery voltage and it was 3.68v and working fine in another light.
I put a fresh battery in and it did the same thing, and when I checked the voltage it was 3.69v.
Both batteries were 4.1v when I started and I know my meter is pretty accurate.
I am wondering if anyone else has seen this?
Is there some type of adjustment I can do?
Not sure if there is much you can do about that. The low voltage warning seems indeed very early. It is measured under 3A load btw so the voltage is then a bit lower. What batteries were you using? If they are really bad the voltage under load may get so low that the LVP kicks in very early too. The solution is using higher drain type batteries that keep voltage better under load.
I was afraid of that.
The Batteries are Old and low drain…
I was planning to purchase some new batteries but life got in the way before I had a chance.
