I have both. I was impressed with the one cell until I saw stuff like the FT03.
It is high-low-off, so two click
Hold for SOS
I did the DC Fix on one for a dedicated house light, don’t want throw when I am looking for something under the table.
I tried to do a side by side beamshot inside, but the camera just can’t get the definition. I will try to do one outside.
The 2 battery version is on-off and ramps. It is like 2X as bright side by side.
My S43S - albeit not a big light - also does aggressive stepdowns. If you run it on turbo it immediately does a huge stepdown, then waits a few seconds, then a does another huge stepdown…resulting in like <100 lumen.
I’m not thinking of Anduril.
I find the NarsilM method of setting stepdown temp (hold light until it’s too hot) to be very hit & miss. Much better to manually enter a temperature (eg Anduril) because at least then you can test it, go /- 1, test it, go/- 1 etc.
Ha ha, the S43S is just the small light I was thinking of that initially did a too fast step down. You might need to manually set your S43S. I did and got much nicer, smaller step downs. Astrolux S43S Stepdown after custom temp adjustment - YouTube
Just to clarify, a 32% drop is not a lumen percentage. It’s 32% of the ramp scale. The ramping has 150 steps, so it should go from step 150 (Turbo) to step 102 which is like a nice medium level.
It’s interesting that his review saw the light step down at 40°C. I think it should be closer to 55°C. That’s usually the default. He may need to manually set the stepdown temp as well. (Start with a room temp light, activate manual setting, then hold light until you think it’s hot enough and shut off. It memorizes this level.) It works great for me. If your having issues, make sure the lights internal temp is cool. I let it sit for a couple hours to fully cool down before setting the manual temp.
I don’t know if the Anduril temp setting is better or not. I haven’t really played with it much. The FW3A is the only Anduril light I have. Once I calibrated the room temp, it’s step down seemed fine. I don’t really like the delayed turn off in Anduril and a few other things about it. So I’m more a Narsil guy. You can turn off all temperature stepdowns if you want and let your hand tell you when to turn it down. That’s what I’ve done for years with my L6 that has old Narsil firmware on it. It’s all about what you prefer.
I would like to see Zeroair reset the thermal calibration or at least try it with a milder battery, not that high current 21700.
Nope, opposite. If we pick a brightness level of 1000 lm and have 3 different size led dies (let’s use Cree because their efficacy is pretty consistant) xp-g3, xp-l2 and xhp50.2, the bigger dies will use less amperage. Less amperage means less power used which equals better efficiency as far as battery run time is concerned.
xp-g3, die size 1.44mm2 = 2.5A
xp-l2, die size 1.9mm2 = 2.2A
xhp50.2, die size 2.94mm2 = 2A
(From raw led tests and different testers, so don’t treat as super accurate, but it’s accurate enough to show the differences)
Note that Luminus SST-40 has about a 2mm2 die size and would be about 2.2A. Very similar to xp-l2 until you get to the higher amps.
Of course, the xhp50.2 is capable of 16A and the the SST-40 9A, so if you use Turbo a lot the 50.2 will drain the battery quicker.
As always, get the one that best fits your needs. FT03 has less lumens, smaller hot spot and further throw. Mini has more lumens, bigger hot spot and less throw. The spill lighting is quite different between tir lens and reflector. Different UI’s, mini has aux LEDs. What do you prefer?.
Since I am into laser I would be lying if I said I wasn’t impressed by the acebeam w30. But that price tag just doesn’t sit well with me. I was looking at the C8g from sofirn, I already own a c8t. I don’t like how it heat soaks and stay useless, thought the C8g would be an upgrade then I stumbled on to ft03 as direct competitor. Then I leaned the imminent release of mf01 mini. I always wanted a fancy aux, and with a throwing capable light that’s like perfection. Now I learn mf01 mini will throw less, just how much less?
I am starting to a mass a collection here and may just separate my needs. Got the chaselight now, btw the thing is a security device as a weapon lol.
I have both models of the FT03.
The first version can stay on turbo much longer. It does not heat up very fast at all. 5 minutes is no problem. Not as much total light but more throw.
I like it, I am skipping the FT03 for now until I get tired of these other throwers. I think the FT03 isn’t really pocketable, and I feel that everything non-pocketable is in the same category for me (for now), so the chaselight will do. We can discuss chaselight in the other thread.
I caved in and bought it, can’t pass the deal at $30. Anyone thought of using an ice pack type material as a holster/wrap to help heatsink heat during use? Not looking to use a prechilled one but just some thing to wrap around the body while remain functional and easy to carry. Also the heat must be conducted to the body well, hopefully that’s already done stock.
