26650 Batteries
Small world, I am a 2010 grad.
Viktor - hard to tell, but I will note.
BUMP for updates to my post #114.
Just a quick tip on the battery space 3600 LiNiCoMn. Since the +B is so big, flat almost looks like the -B (and I was bored waiting for the discharge capacity test), I got a little creative with the sharpie pens. Safety first!!
I don't see these listed on the first post:
MNKE 26650 4000MAH LI-ION BATTERY (IMR)
http://www.intl-outdoor.com/mnke-26650-4000mah-liion-battery-p-223.html
Are these supposed to be the "safe" chemistry IMR? The kind that will tolerate deep discharge and very high current discharge?
Viktor
@kramer5150:
Very nice, no chance to make a mistake that way. At least if you're sober when operating those. :)
I see now that MNKE 4000mAh IMR is at the moment out of stock on IO. So is 3500mAh version.
Yes, out of stock, and the 3500 as well. I talked to Hank and he said he did not know if he would be stocking these again. I have read elswhere (CPF, I think) that the manufacturer is not going to be producing anymore of these cells, which is a shame.
There is a new version of the KingKong INR26650E with raised top:
http://www.intl-outdoor.com/kingkong-inr26650e-raisedtop-4000mah-liion-battery-p-370.html
Ahhhh, Hank must be reading this thread. I'll note it in the OP, thanks for the info, N.Shock.
I just found Hi-Max branded protected 26650's from the same Ebay seller who carries the Hi-Max 18650's. Pretty steep at $27.50 + $7.00 shipping! Link here.
-Garry
Thanks for the link, Garry. A quick Google search for Hi-Max Electronics and they do not show 26650 as one of their battery offerings, but their website could be out of date if these are relatively new. However, I have a source for H-Max, I'm going to check to see if these are indeed legit.
EDIT: Confirmed with Shane at Protacticalshop19 that Hi-Max does have these and the ones sold by pingyi.co.ltd are indeed real. I'll update the OP to reflect these in the Protected section. Shane also confirmed they use a Samsung core.
Pok did a capacity test on a trustfire flame 5000 protected cell and it came up just shy of the 4000 mark (3946 mah @ 1A discharge).
thread here....
https://budgetlightforum.com/t/-/7999
Also... DX correctly specifies this on their product description....
"- Capacity: 5000mAh (actual 4000mAh)"
http://www.dealextreme.com/p/trustfire-rechargeable-3-7v-5000mah-26650-li-ion-batteries-pair-107232
Is someone tested 26650 battery form buyincoins?
http://www.buyincoins.com/details/new-26650-4000mah-4-2v-lithium-rechargeable-battery-blue-product-12518.html
FYI
In Thaicpf , Dong did three of capacity test on a trustfire flame 5000 protected cell from ebay, (package include TR-J12 )
There are capacity about 2A all of them.
Do you mean 2Amp-Hours storage capacity?... or 2Amp current delivery (before voltage sag)?
thanks
Yes, I mean 2Amp-Hours storage capacity.
He did a test like me in Trustfire A8 thread.
Thanks, kramer. I'm not seeing where the Trustfires that Pok tested were purchased. EDIT: Pok responded in other thread that origin of the cells is unknown. I would not consider the Trustfire 'brand' to be tested without knowing source of the tested cells. Too many fake TFs running around.
On DX, I'll change the description in the OP when DX changes the description in their product headline and wrapper. Many folks don't read down into the details....
Oh right, excellent point... its just the heat shrink, they can stick ANYTHING under there and pass it off as a quality product.
Yikes... probably an old cell from the recycle bin, or maybe an 18650 inside a fake shell. Definitely some scams out there.
None that I'm aware of. Very little information on this battery, but I'll add it to the OP in the Unprotected section.
I just finshed testing one it was 4.3Ah
https://budgetlightforum.com/t/-/8030
Every battery i have brought from them has been crap.
