Test/review of Vapcell INR18350 1100mAh (Purple) 2019
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 17 hours ago
DSC_9272
Official specifications:
  • Model: INR18350 1100mah 9A
  • Size: 18.1*35.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 1100mAh (0.2C discharge)
  • Min capacity: 1000mAh (0.2C discharge)
  • Weight: Max:26g
  • Internal resistance: Max:25mOhm AC 1kHz
  • Standard Charge: 500mA,CCCV 100mA cut-off
  • Charging Time: 3hours(standard charge)
  • Quick Charge Current: 1500mA
  • Max Continuous Discharge Current: 9A
Vapcell%20INR18350%201100mAh%20(Purple)%202019-info
The latest Vapcell high capacity and high current 18350 cell.
DSC_9271
DSC_9273 DSC_9274
DSC_9275
DSC_9276
DSC_9277
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Capacity
The two cells matches nicely and can also deliver the rated 9A, but they do have serious trouble at 15A.
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Temp-7.0
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Temp-10.0
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Temp-15.0
Vapcell%20INR18350%201100mAh%20(Purple)%202019-CapacityTimeHours
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Energy
Vapcell%20INR18350%201100mAh%20(Purple)%202019-PowerLoadTime
Vapcell%20INR18350%201100mAh%20(Purple)%202019-TripCurrent
Vapcell%20INR18350%201100mAh%20(Purple)%202019-Charge
Vapcell%20INR18350%201100mAh%20%28Purple%29%202019-Pulse-1A-10-10-2.5V-IR
Conclusion
This is from the new high power 18350 generation and it looks good.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
CRX
CRX's picture
Last seen: 7 months 1 week ago
Thumbs Up
mitsuki08
Last seen: 19 hours 42 min ago
Thanks for the review as always HKJ!
maukka
maukka's picture
Strange that they went backwards. This is worse than the earlier 18350 1100mAh, but at least this pair of the newer cells were closer to each other. Aspire still reigns best.
Dlux
Last seen: 3 hours 23 min ago
Not so strange, it seems factory opted for downgrading product specifications to solve performance inconsistencies
SKV89
Last seen: 1 week 6 days ago
Unfortunately the Aspires were discontinued a while a go. Luckily I bought some after knowing they were about to be depleted. I also bought a bunch of earlier Vapcell 18350 and they were similar in performance to the Aspires. The more recent Vapcell 18350 are from the more recent batches of the same cell after the manufacturer downgraded the performance. These are my test results from earlier batches:
Aspire 18350: 1198/1102/1166/1160 mah
Vapcell 18350: 1156/1155/1019/1149/1126 mah
The general performance is about the same indicating same cell. There is one Vapcell that tested 1019mah and I retested it to be about the same capacity so it is definitely low but still better than most other 18350.
Superstocker
Superstocker's picture
Last seen: 1 day 23 hours ago
Thanks HKJ!
Barkuti
Barkuti's picture
Last seen: 6 hours 17 min ago
If you look carefully using HKJ's comparator, the curve shape of the “Aspire” cells (Aspire, KeepPowerUltraFireVapcellis was different. I can't say if this is due to a reduction in manufacturing costs by the same OEM, or a different OEM product altogether.
The BestFire IMR18350 was the first high discharge 1000+mAh 18350 cell reviewed by Henrik to show such (different) discharge curve shape.
It also looks like a progressive regression if you follow the reviews by date: Aspire 1st; then KeepPower, Vapcell and UltraFire (BMS protected); at last BestFire and the newer Vapcell.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
vapcell Dennis
vapcell Dennis's picture
Last seen: 2 hours 43 min ago
Compared with the previous vapcell 18350 1100 MAH 10A, the 9A battery capacity has been reduced a little, but the power has been improved a little, and the consistency is better.
