Would you be willing to make my total request of LT1’s – Two (2) ?
Below is copied from the spreadsheet to make finding me easier if needed.
1202 russthetoolman 1 2163
Thanks !!
Russ
That’s the Thorfire button, I guess they reused an old 3D model button for that picture.
I think they have a huge box with a gazillion of them, way back in 2015 someone must have made a writing error and ordered 100 times too many and they are still using them up on every new flashlight model
Haha, surely they’re not using that? It would be like Olight putting 47s logos on their lights.
Unless they rename the light to Tentlight LT1 or something
Interesting that 600lm is now the offical number, as fas as I remember that was only an educated guess and the real brightness of the production model was never tested.
And why are they using the forum pictures on Amazon? They don’t look very professional and some of them aren’t even showing the final version!
3. The grammar in this question is hard for me to understand. I think the answer is that's the way ToyKeeper programmed it. You can never change the level wanting to default to at (smooth ramp) or near as possible (stepped ramp). You can change the bottom and top of the ramps independently for each ramp type, and the number of steps for the stepped ramp, but not the default level at which the lantern will turn on with a single click after the battery is replaced. Once the user changes the factory defaults, they can be reset, but I don't think that got put in the manual as to how, at least I didn't find it at glance right now.
Sorry, maybe I'm really confused and missed this point, but this is referencing the default brightness at turn on after battery reset? Because isn't that programmable now? I thought TK added 5 clicks from on to set current ramp level to default power on level, regardless of what level you were at when you turned it off. And then another 5 clicks from on, sets it back to her default from battery reset, and memory mode when you use the button to turn it on and off?
At the risk of seeming like jumping on the increasingly large bandwagon, can I please be added to the list for two more – I think that’s a total of 8 lanterns.
Et voilà, the french translation (PDF) is officialy available for public release, now crossing my fingers to meet Sofirn Batch#2 printing schedule. (...)
Merci beaucoup! I have put a copy of that file onto the public sharepoint. So, now we have English, French and German in one shared folder, see link in the OP.
I'm going to forward it to Sofirn tomorrow. If all works out we get to see the multilingual [EN/FR/DE] manual with batch #2.
3. The grammar in this question is hard for me to understand. I think the answer is that’s the way ToyKeeper programmed it. You can never change the level wanting to default to at (smooth ramp) or near as possible (stepped ramp). You can change the bottom and top of the ramps independently for each ramp type, and the number of steps for the stepped ramp, but not the default level at which the lantern will turn on with a single click after the battery is replaced. Once the user changes the factory defaults, they can be reset, but I don’t think that got put in the manual as to how, at least I didn’t find it at glance right now.
Sorry, maybe I’m really confused and missed this point, but this is referencing the default brightness at turn on after battery reset? Because isn’t that programmable now? I thought TK added 5 clicks from on to set current ramp level to default power on level, regardless of what level you were at when you turned it off. And then another 5 clicks from on, sets it back to her default from battery reset, and memory mode when you use the button to turn it on and off?
I bet you are correct. I don’t have that feature on my D4, not sure if my Q8 does or not. But there is a reference to it in the picture. However, there is no description in that text. I guess for now that can be considered an “expert user” feature.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
I bet you are correct. I don't have that feature on my D4, not sure if my Q8 does or not. But there is a reference to it in the picture. However, there is no description in that text. I guess for now that can be considered an "expert user" feature.
Fair enough haha. Yeah the feature in thinking of, if it's the same one bring discussed, was officially released by TK in June. So if you haven't compiled since then, then you wouldn't have it. That's also when she added momentary strobe modes, super cool
If you could add me for another 2 lanterns please? (total should be 4 then) Just because it seems this will be a 1x use code for 1 light each from my understanding.
will there be a possibility to pay with paypal? also I would like to be moved downward the list. From nr 300 something to nr 500 something. I’d rather have a 2nd batch light.
Idiot proofing something only creates improved idiots.
Not sure how payment is set up since that’s up to Sofirn. However you don’t have to buy a lantern even when you get the PM and so can wait for batch #2. Per Sofirn the batch #1 codes are good for 30 days. And no doubt they can be extended by them.
Due to the huge influx of additions since Sunday night I decided to push the new updates to the files linked to in post #1. If you have a moment check that your user name and lantern count is correct in the Excel files.
Amazon doesn’t allow for Paypal AFAIK and I buy from them a lot.
I have a Credit Card from PayPal.
It is a Master Card.
@SIGShooter,
Thanks !!
Russ
I’m in for 2, please add one more for a total of 3.
Hollybrook 2 1302, 1394
Please add me for two more (total of 4!)
MtnDon (me)
would like to add a third reserve.
BLF Member Map, add yourself
My 10th Annual contest entry.. My 9th Annual contest entry. My 8th Annual contest entry.. My 7th Annual contest entry.. My 6th Annual contest entry... My 5th Annual contest entry... My 4th Annual contest entry...
My DBSAR inspired SRK lantern hand made mod
link to djozz tests
+1 for total 2x
More than likely I do not need another one but just in case I do and especially if the code is not generic..
I was down for one, but would like to add one more for a total of 2.
Thanks, just keeping track of orders must be a nightmare.
Please put me down for one more
Can you please put me down for 1 more? Total 2. Thanks!
Please put me down for a second one, total of two.
Thanks to everyone who have worked on this.
Please put me down for one. Thanks
Please add 2 more for me for a total of 3. Thanks!
I’d like 2 more please for a total of 4. Hoping for colors after the black finish rolls out!
The Interest list by entry number file is the order that the PM’s will be sent out if anyone is curious about that.
Here are the additions:
2596 lousybreaker
2597 Rayoui
2598 SwissFlashy
2599 GRLights
2600 magnethelm
2601 psmbfuer
2602 adam7027
2603 adam7027
2604 Phlogiston
2605 dlpkl
2606 Rahelming
2607 Rahelming
2608 nicois
2609 man of light
2610 Yacob29
2611 ryanjennings
2612 ryanjennings
2613 ryanjennings
2614 ryanjennings
2615 Kulumatic
2616 Lilyspoppa
2617 qandeel
2618 qandeel
2619 qandeel
2620 brightlights
2621 Andmiller
2622 Andmiller
2623 Andmiller
2624 woodyt
2625 atobe
2626 TanteElfriede
2627 WolfDiesel
2628 Bugdoc
2629 Bugdoc
2630 Vietnam.Vet
2631 Phaze13
2632 Ucm45
2633 zoinks
2634 bulbed
2635 GhostofHarry
2636 DarthTader
2637 DarthTader
2638 theWoodster
2639 theWoodster
2640 psmbfuer
2641 lachesis
2642 lachesis
2643 JackMarsh40
2644 Bmallak
2645 Bmallak
2646 carmantl
2647 carmantl
2648 carmantl
2649 snoopstah
2650 hannes13
2651 Raptor2018
2652 Raptor2018
2653 brenden23
2654 brenden23
2655 Kevin Z
2656 Kevin Z
2657 Kevin Z
2658 amishbill
2659 amishbill
2660 Williamskw86
2661 Joat
2662 Akgunwinner
2663 liquidrazer
2664 liquidrazer
2665 belgarath
2666 belgarath
2667 belgarath
2668 belgarath
2669 octav
2670 Akgunwinner
2671 rogueRobot
2673 Sparks65
2674 Sparks65
2675 Kionix
2676 enix316
2677 enix316
2678 freethink
2679 SociopathicSamaritan
2680 d_t_a
2681 d_t_a
2682 LOTL
2683 Hollywood88
2684 PillowRobot
2685 Melraidin
2686 Melraidin
2687 bonC
2688 schlafsack01
2689 schlafsack01
2690 lumiere
2691 BillyBobJoe
2692 BillyBobJoe
2693 lroach
2694 amishbill
2695 blammergeier
2696 Givememyhatback
2697 Scorpia
2698 Taschenrechner
2699 Taschenrechner
2700 Big_Sam
2701 Big_Sam
2702 madcrow
2703 madcrow
2704 madcrow
2705 halms
2706 halms
2707 halms
2708 LDIBP
2709 LDIBP
2710 LDIBP
2711 Bmallak
2712 Bmallak
2713 Kuato
2714 JorisFRST
2715 JorisFRST
2716 pthartung
2717 racnigel
2718 solRNY
2719 solRNY
2720 solRNY
2721 KgaBombadier
2722 Watermanchris
2723 Watermanchris
2724 Escew
2725 Friendlyfodder
2726 Bullmajor
2727 Bullmajor
2728 Bullmajor
2729 Bubblehead
2730 LemonLime
2731 LemonLime
2732 olles
2733 Speedfreak32
2734 TheAlchemist
2735 bakeshow
2736 bakeshow
2737 Ristafas
2738 Cumbo
2739 Old Davo
2740 Old Davo
2741 Old Davo
2742 Old Davo
2743 Juls Boo
2744 Juls Boo
2745 Juls Boo
2746 kase
2747 JoeH12.81
2748 JoeH12.81
2749 Thescreensavers
2750 Thescreensavers
2751 JakeDjanitor
2752 Kardolf
2753 mopar440_6
2754 mopar440_6
2755 mopar440_6
2756 mopar440_6
2757 mopar440_6
2758 shirnask
2759 Dougdimadome
2760 DBSAR
2761 DBSAR
2762 russthetoolman
2763 Hollybrook
2764 maxacarp
2765 maxacarp
2766 MtnDon
2767 Lagittaja
2768 Trouthead
2769 northbeard
2770 northbeard
2771 Caleb-v
2772 Mondak
2773 seriesone
2774 jakeblat
2775 nibble
2776 nibble
2777 Tixx
2778 Tixx
2779 KinggDogg
2780 KinggDogg
1 more for me please. i think that makes 4
I am sorry, I thought I was only at one. I only need two!
I’d like 1 more please for a total of 2.
A orange cerakote coating would be nice.
