ROFL… the first link says “BLF LT1 Lantern, sofirn USB Rechargeable LED Lantern 4 18640 Batteries Excluded” and the second, as you said, says “BLT LT1 Lantern, Sofirn USB Rechargeable Lamp with 4pcs 18650 Batteries 3000mAh”
wait for one to be sent to you via PM from Sofirn. They are running the show now. If you are not in the first 500, you MAY have to wait a couple weeks or more.
I’m #9 on the list, and I haven’t received the code - are they going in order? Or do I need to request one directly from them? I understood from their earlier post that they’ve already started sending out Amazon codes, so I’m not sure what to expect.
Thanks for all your work on this!
The batch one codes will work for batch 2 assuming they are ready within 30 days. If not I’m confident that Sofirn will extend the 30 days. But of course I’m only speaking for me and not Sofirn in any way or manner.
I have yet to see protected Sofirn cells. None of the Sofirn lights I have came with protected cells. Unless I’m blind the link you supplied is to unprotected cells as well. From my testing Sofirn cells are not something you would buy on purpose. Capacity is OK but only at extremely low amperage. Max amperage is about 2.25 amps which is well horrible.
