Does this also have a turbo mode?
Can the cap-base be bought separately? or what is an alternative. I need to cover the lantern base when the batteries are not connected.
Actually, the English term "battery" has two meanings in German.
Battery = "Akku(mulator)" = rechargeable battery
Battery = "Batterie" = disposable battery
Seams logical and akku(mulator) made it relevant. Thx
Highly unlikely. Iām guessing it ramps all the way up to 600 lumens. I donāt see the point having a higher turbo being a lantern thatās designed for runtime
Is it too late to add my name to the list if possible? Thanks
- here.
Ordered via AliExpress, have a tracking number and waiting for delivery
#1463 here.
Really! 974 and no pm
Juls Boo:#1463 here.
Ordered via AliExpress, have a tracking number and waiting for deliveryReally! 974 and no pm
No need for PM if youāre ordering from Ali or eBay.
I believe anyone can order from aliexpress at any time without a PM as long as their name is on the list.
Just an opinion of mineā¦. having the LT1 available from Amazon with a PMād code as well as being available on eBay and aliexpress is very confusing. I know this ordering process is completely out of our hands so this is just a statement for future consideration by anyone else involved in a project.
If anyone on the list can order from ali or ebay at anytime what is the point of the numbered list? It becomes a free for all.
Codes are only needed for Amazon but they all ship from China
Th558:Does this also have a turbo mode?
This is correct. The LT1ās primary purpose is to be āenoughā lighting to let you function normally over an extended time. In a situation where normal lighting is not available, this should be enough light to allow it. It was never designed to replace a 200w chandelier.
That said, there are - I believe - solder pads on the driver to let those who want to trade runtime for more light. If the details are not in the instruction manual, dig through the first post and you should be able to find them. Youāre not going to hit 4 digits of light, but you can get āmoreā.
Not a bad idea.
Light Years: DBSAR:Production prototypes were sent out to TK, Lexel & myself to run through a battery of tests to work out bugs, but there were no free current production units sent.
Itās a shame that you (and the rest of the team) arenāt getting a free production unit. With all the time you invested in this project, you really deserve one. With nearly 3000 units on the interest list, thatās $150 000 worth of sales for them (plus what they will sell afterwards).
Hey Sofirn, itās not too late to show some well deserved recognition to those who designed a product that will bring you a few $100K in sales.
$150k in sales, but definitely not $150k in profit.
Having said that, it would be pretty nice if they sent the couple of ppl that worked on it a special limited edition. We would all drool over it and then some people would buy the LE version on top of what they are already buying.
Funtastic: Th558:Does this also have a turbo mode?
Iām pretty sure youāre both incorrect. We went over this when working on the manual. As it was explainedā¦ By default the light does not ramp all the way to the max possible output. It ramps to the āceilingā which is not the max possible output. As such, the āturboā is brighter. You can change the ceiling to the max possible output, but thatās not how it ships.
Of course itās always possible that we were given incorrect information despite making every effort to ensure the accuracy of it.
amishbill: Funtastic: Th558:Does this also have a turbo mode?
Iām just going by what TK said way way backā¦
About the level 65 thingā¦ It is behavior inherited from other lights which use the same firmware. On many of them, the default ramp goes from 1/150 to 130/150, and then there is an additional turbo level at 150/150. When it turns on, it tries to hit 65 because it is visually halfway up and makes a good āmediumā mode.
On the lantern, there is no turbo by default. Itās not bright enough for that to make sense. So the ramp goes from 1/150 all the way to 150/150. It still defaults to level 65/150 after a battery change though, since itās still a pretty good āmediumā mode.
As for the floor and ceiling levels, the ceilings are both set to the highest level by default. The smooth ramp floor is set to the lowest level. And the stepped ramp starts at 10 and has 5 steps.
Smooth: 1 to 150
Stepped: 10 to 150 in 5 steps: 10, 45, 80, 115, 150
Smooth: 1 to 150
Anything is possibleā¦ The manual now says that the ramp goes all the way to the max possible output level. It also says thereās a turbo mode. I canāt vouch for the accuracy of it.
could you put me down for a 2nd lantern. thanks = total is 2
Stereodude: amishbill: Funtastic: Th558:Does this also have a turbo mode?
Smooth: 1 to 150
TK may have changed the final release of the firmware for the production units, i am unsure of that. but the production prototype i been testing has a smooth ramp that goes from roughly 10% up to 90% brightness, the 90% being the ceiling of the ramp config. A quick double click brings it to 100% maximum. Technicallyit is not a turbo as it donāt step down & is not a āoverdriveā mode like some flashlight turbo modes are considered. The stepped ramp config goes to 100%
Iād like to purchase 1 more, for a total of 3. might as well give some gifts.
Love the teamwork here!
