MF01S Issue-SOLVED
4 posts / 0 new
gismoZ
Last seen: 1 year 11 months ago
MF01S Issue-SOLVED
Hi. I have an issue with my MF01S.
When I screw the head, the sst20 leds blink once but neither the switch nor the aux leds light up.
The flashlight works but it functions problematicaly. I can only switch it on/off and use ramping.
Neither turbo, strobes, battery check etc.
Also, each time that I turn it on, the light pulses for ~1 second.
The last time that I used it, it was working fine.
I tried cleaning the contacts and using different batteries and battery tube but no luck.
Any help will be appreciated.
Edited by: gismoZ on 10/17/2019 - 13:21
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 16 hours ago
Is your light in muggle mode?
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
gismoZ
Yes, I should have read the manual more carefully! Thank you! Thumbs Up
KevinZA1988
Glad I could help!
