Pic heavy!!!Review Lumintop EDC18(or as I call "the GREEN BUNNY")
12 posts / 0 new
jjp888
Last seen: 1 year 1 month ago
Hi all,today Iam really excited to share with you my experience with the new Lumintop Edc18.
As the Lumintop fan followers already know,this is the side switch version of their popular Fw3a flashlight.The Fw3a was an instant sucess due to all the features and power ,the tiny pocket light posessed.But still there was room for improvement as a daily carrier and Lumintop by making the Edc18 have managed to solve many of them.
Compared to the FW3A the EDC18 has ,almost similar dimensions.It is slightly taller than FW3A to accommodate the side switch .
The first thing that, I adore about this light as soon as I put the battery in it ,was the constant glowing "Green Bunny " on the side switch.It looks bright and very beautiful.Lumintop have chosen the green light for the side switch which gives a great appeal to the fully black light .It makes the flashlight very easy to find at dark.
The side switch in my opinion is the best one that Lumintop have made so far.It feels great to touch and the clicks are super crisp, absolutely no squishiness like the other bulged side switches on Odf30 or Edc05c .Just pure firm clicks.
Personally liked the Fw3a tailswitch ,which had great ergonomics.But as everyone knows, its was prone to accidental activation pretty easily,and also the tail switch was in several tiny pieces which comes apart very easily and was easy to loose.So in dark situations ,you must be particularly careful to insert the battery via head portion.Also you absolutely had no way to mechanically lockout the FW3a.In an EDC flashlight ,these tiny things do counts and Lumintop have solved it perfectly using the side switch on edc18 .The side switch is not prone to any accidental activation ,and if you still don't trust it ,you can always mechanically lockout by a slight twist of head or tail cap.The green bunny turns off to confirm the mechanical lockout. Cool right?
One of the first questions which I had in my mind on knowing about this light was ,how much current the side switch green bunny consumes.And I tested it at once I got the light in my hand ,it is very low at just 111.2 micro ampere,which for a 3000mah battery means it will take more than three years for the battery to be fully drained.
The FW3A had lower current drain at 22.4 micro ampere as there was no backlit switch or aux leds
Some manufacturer's specs
Emitter: 3 Cree XP-L HI,Nichia 219CT or Luminus SST20 LED
Optic: Standard TIR optical lens
Flux: ~2800 lm (XP-L Hi)
Intensity: ~10 000cd ANSI throw ~200 m (XP-L Hi)
Firmware: Free software called Andúril
User interfaces: [1] Defaulted SMOOTH RAMPING. Instant access to TURBO mode is also provided. [2] STEPPED RAMPING UI. [3] MOMENTARY mode. [4] MUGGLE mode. [5] Electronic LOCKOUT.
Other functions: Battery check, sunset, beacon, tactical strobe, party strobe, bike flasher, candlelight, lightning storm
Battery: One 18650 cell. An unprotected cell is recommended. Max. length 66mm. Cell is not included.
Driver: FET+7+1 driver. Low parasitic drain while OFF
Body: Aluminum with hard-coat anodizing
Switch: Electronic side switch with back-up light
Ingress rating: Equivalent to IPX8
Weight: Approximately 76.5 g without cells
Size: 27.8 mm Ø head x 93.9 mm length
Others: Magnetic tail cap, reverse stainless steel body clip
The light came in a similar package as to that of the FW3A.
The accessories include ,a flexible glow in the dark diffuser
two spare orings with a keyring ,which I guess is for lanyard attatchment
a lanyard
and a reversible pocket clip
The GITD diffuser is a very useful accessory.This also helps to use the full potential of light like the candlelight or the thunderstorm modes,which are very to use at night.
The diffuser retains its glow even after turning off the light, for quite some time ,making it easier to find at dark,incase you misplaced it
optics is similar to the Fw3a with a three led setup.But unlike FW3A it doesn't have a glass infront of the plastic optic.
Haven't tried removing the stainless steel bezel,as I fear it may scratch the plastic optic. Flashlight is my opinion is not for the modders as ,the head portion is press fitted and with the side mounted e switch, it will be difficult to do any further mods unlike the fw3a ,whose head comes apart quite easily.May be someone more knowledgeful in modding , can give a clearer idea about this.
The tail cap is having a dual gold plated spring setup for better conductivity.
The Edc18 ,unlike the Fw3a is no longer an insane light, although you have the same output levels.
The stepdowns are more aggressive ,to keep everything cool.This does mean ,we no longer have a constant higher modes as ,the temperature controls are more sensitive to heat build up now.On the flip side ,this makes the light more safer to use and gives more confidence to the user.
The flashlight build is very sturdy,it has a chunkier head with heat fins for effective heat dissipation.The whole black anodization is uniform and is in a matt finish.
There are diamond cut knurlings on the battery tube and tail cap giving a good grip to the flashlight.
The head design is very attractive and functional.It has a flat area to accommodate the side switch, which also acts as an antiroll feature to the light.
The Edc18 has a reversible pocket clip unlike the Fw3a which was fixed.This additionally lets you to use it as a headlight by cliping it on a cap.
The flashlight ,also has a lanyard hole ,if you prefer to use those.
Talking about the optics and beam,it is similar to that of the FW3a.I got the xpl hi version in cool white.The cool white does help in brightening the spill area,which is great especially at longer distances.The beam like Fw3a is pure floody beam with adequate throw,perfect for edc carry.
View from a building, ~ 45 meters tall
To sum it up
Pros,
1.Carries on all the wonderful features of Anduril from the FW3a
2.Better designed for edc use.
3.Backlit side switch is really well made.Gives firm clicks.No accidental activation
4.Always on side switch light,makes it easier to finf at night.
5.Reversible pocket clip design,gives additional versatility.
6.Mechanical lockout feature.
7.More sensitive temperature control.
8.Lanyard hole option available.
9.Square cut threads which are well lubricated.
10.Comes with a flexible GITD diffuser.
Cons
1.Still no room for protected batteries.
2.No onbard usb rechargeability.
3.Tailcap magnet is weak in my opinion,not serving the intended purpose.(Problem already resolved in current models as per Lumintop.)
4 Would like to see an option to choose a blinking side switch light as I think will make it even more easy to spot at night .
5 No glass protection for the lens unlike the FW3a.
Half knowledge is a Dangerous thing!.
Edited by: jjp888 on 10/28/2019 - 03:49
withoutink
Nice review
Cheers-
Withoutink
My Flashlights
Instagram | YouTube
AbnInfantry
Last seen: 19 hours 32 min ago
Thanks for the review. I’m waiting for my EDC18 to arrive from Banggood. I’m disappointed to read about the weak magnet.
mattlward
mattlward's picture
Great pics! What part of the world are you in? That scenery is really cool!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 34 min ago
That’s strange. I don’t think its firmware is any different. It should be exactly the same as FW3A.
Maybe it just has the sensor calibrated to a different value? Or maybe it ships with an older version of the firmware?
If it’s a calibration difference, you could probably find out by going to tempcheck mode while both lights are at room temperature. They should blink out the same value, or almost the same. If one is very different than the other, or if either one reads out something which isn’t close to room temperature, it probably needs to be calibrated.
Or if it’s an old version, it might still have a hardcoded regulation pattern called “hard turbo drop” which was eliminated from newer versions. You can probably tell based on whether lockout mode has 2 brightness levels (new) or just 1 (old).
KevinZA1988
KevinZA1988's picture
Last seen: 1 day 9 hours ago
The temp sensor is probably not calibrated… My EDC18 has slightly better thermal performance than my FW3A’s since I calibrated ,the temp sensor and that is expected because of its more thermal mass. I highly recommend calibrating it.
And the magnet has performed its duty very well. It sticks to my car, fridge, windowsills, electrical distribution boards etc with no issues. It sticks to everything almost as good as my Olight S2R Baton II does, and the Olight is a bit lighter.
The stock one piece optic isn’t bad but I will eventually swap it for a Carclo 10511 and sapphire lens.
Great review, great pictures.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
jjp888
KevinZA1988 wrote:
The temp sensor is probably not calibrated... My EDC18 has slightly better thermal performance than my FW3A's since I calibrated ,the temp sensor and that is expected because of its more thermal mass. I highly recommend calibrating it. And the magnet has performed its duty very well. It sticks to my car, fridge, windowsills, electrical distribution boards etc with no issues. It sticks to everything almost as good as my Olight S2R Baton II does, and the Olight is a bit lighter. The stock one piece optic isn't bad but I will eventually swap it for a Carclo 10511 and sapphire lens. Great review, great pictures.
Thanks,for the information about magnet.I just contacted Lumintop .They confirmed that only the magnet in first batch of 20 were weak.But they resolved the problem in their later batches.
About the step down in turbo,I will test again with temp sensor recalibrated.
Old Mate
Last seen: 1 year 1 day ago
Thanks jjp888
My edc 18 has a very nice linear step down – more like a very smooth ramp down. [ i calibrated the thermal sensor and set step down to 55c ]
And my magnet is very strong- very cool light.
Old Mate
Williamskw86
Last seen: 9 months 2 weeks ago
Nice review, thanks for the info. I ordered one with the Sst20 from Banggood last week so I’m excited for it to come. I’m hoping mine is the new version.
D'AVerk
Last seen: 2 weeks 1 day ago
Is anybody know tint of SST-20/4000 in this flashlight?
atobe
Last seen: 16 hours 28 min ago
Looks the same as my FW3A, FW1A put the beams next to each other can’t tell the difference.
ᕦ(ò_óˇ)ᕤ I can always be wrong, probably 75% of the time.
gregor
gregor's picture
Last seen: 13 hours 47 min ago
Very nice review, thank you.
