Thanks Barkuti, it's nice learn something new, my load tester is probably not the best ever, but neither are my cells I guess :)
I will try the same tests on my Sofirn 18650's now.
Unfortunately 5A is my little testers max.
I do not have fancy discharge testing gear. For me, I drop a cell into a known light and use a large gauge current loop and voltage monitor and cook the cell in something that draws like mad. Look for sag and current draw response.
What are you talking about?
This is not fancy: Massive post on where to get lithium-ion batteries everywhere in the world! Look at Post 2-5 for info, And Canada Post 123 - #53 by BlueSwordM
What is the active load? Model number. Also, could you post a pic of the homemade cell holder? 3 amps is a good enough test for me. I would like to be able to rate cells when I get them and they every 6 months to a year later do the same test again. I use a few multi-cell serial and parallel lights and would like to match them at something higher than 1 amp.
Just in case anyone was wondering this is what I use :)
https://www.aliexpress.com/item/32614219909.html
https://www.aliexpress.com/item/32664964301.html
Would love to know how good it actually is.
Would you mind sharing what tester? I have this discharge tester in my wishlist (some feedback here), may buy it some time. But if I can find some cheap graphic rendering device, the better.
Aaah, then you have a 4-wire battery holder. Well, this confirms your “3000mAh” cell is a battery of pretty standard discharge. The following is what likely it is:
Source: https://www.alibaba.com/product-detail/High-Capacity-INR18650-3200mAh-Dlg-3_60805797151.html :-)
Ordered one of these just for the fun of it, looks interesting.
https://www.aliexpress.com/item/4000144172951.html
Think we getting OT here :)
Does their software do English?
Yup :)
Well Dang, but that’s sure a pretty little critter.
I look forward to hearing about how well it works.
Anyone know if the “147”, “151”, etc., is the date code for 30Qs? Ie, the last line, under “SAMSUNG SDI
Pain in the ass Opus was getting heat-stroke again, would drop to 0mA, then back up to 1000mA, then stop, then go, etc., that I redid the cap test at 500mA just to get all 4 uninterrupted. Just put on the second group of 4 this morning.
All finally clocked in in the 2800s, all within like 60mAH but still just a hair under 3000mAH.
Wondering if they may be from a coupla years back and need some “exercise” or whatever to get up to speed.
Damn, I bought six 21700 batteries from this seller https://www.aliexpress.com/item/32846442786.html?spm=a2g0s.9042311.0.0.782c4c4ddz8ljP
It actually looked pretty legit, but I doubt the batteries are. Does anyone know where to get proper batteries with international shipping?
I’m not trusting eBay sellers even though their price seem realistic either.
The wraps say 40A, but the description says 15A.
I’d probably trust them to be 15A…
Do yourself a favour, buy a 12cm computer fan and place it above the charger while 1A discharging. Of course, power it up.
Lishen LS21700SA cells, 3C manufacturer rated (12A). According to Henrik's review the cells get slightly above the maximum recommendable temperature when discharged continuously at 15A.
NKON may ship to Norway for affordable money.
If they’re 15A they’re good enough for my use, but I’m worried they might leak.
I bought some legit Samsung 40T from a french eBay seller to be sure I have some decent ones.
See what I said above. They still hold their voltage well at 15A and can be considered “15A”, albeit technically they're not 15A, just close.
How is a li-ion cell going to leak? Without puncturing the can, that is. And you don't want to puncture a standard li-ion cell, my dear:
Source thread: Testing 18650 Safety - Russian Ukrainian Style
P.S.: some people has managed to make cylindrical cells leak, spot welding the cells wildly by hand. Proper spot welding requires precise timings and current flow.
Mon, 10/28/2019 - 21:15
No, the code format has changed somewhat over the years, but it’s on the metal can itself. See HERE. We also recently discussed this somewhat HERE.
More OT: This is par for the course, but the page repeatedly says it has “6-Bit” high-resolution display, but I’m pretty sure that it actually means 6 digit resolution; a 6-bit resolution would be rather useless .
