Test/review of Vapcell INR18650 2600mAh G26 (Red) 2019
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 17 hours ago
DSC_9316
Official specifications:
  • Model:G26 INR18650 2600mah 25A
  • Size: 18.3*65.0mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 2600mAh (0.2C discharge)
  • Min capacity: 2500mAh (0.2C discharge)
  • Weight: Max:47g
  • Internal resistance: Max:10mOhm AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 25A
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-info
This is a high current 18650 cell with moderate capacity.
DSC_9313 DSC_9314
DSC_9315
DSC_9317 DSC_9318
DSC_9319
DSC_9320
DSC_9321
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Capacity
The two cells matches very fine and capacity is nearly constant independent of load.
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Temp-15.0
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Temp-20.0
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Temp-30.0
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-CapacityTimeHours
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Energy
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-PowerLoadTime
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-TripCurrent
Vapcell%20INR18650%202600mAh%20G26%20(Red)%202019-Charge
Vapcell%20INR18650%202600mAh%20G26%20%28Red%29%202019-Pulse-1A-10-10-2.5V-IR
Conclusion
It is a good high current cell, that can deliver the rated 25A without any problems.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 10 hours 51 min ago
Thanks HKJ! Looks like the LG H26.
JaredM
JaredM's picture
Last seen: 15 min 9 sec ago
Looks like. I didn’t realize that LG changed their cell structure so much. Not only are the labels different, but now they use a ’3-leg’ positive pole like most other manufacturers. This will make discerning re-wraps and fakes a bit more difficult IMO.
Regardless of that, we appreciate the fine review as always HKJ !!
https://fundrazr.com/osturaband
No affiliation, just a fan.
vapcell Dennis
vapcell Dennis's picture
Last seen: 4 days 19 hours ago
yeah ,you are right Smile
shadockan
shadockan's picture
Last seen: 3 weeks 3 days ago
It’s great to talk to a company that has the courage to mention which battery it uses.
Thanks for telling the truth Dennis.
This counts very much …..
We also thank our dear friend HKJ, who once worked for us …
HKJ
HKJ's picture
I test batteries for whoever send them to me, only limit is how fast I can test them.
vapcell Dennis
You are so great and selfless. Thumbs Up
salute
Sirstinky
Last seen: 5 hours 59 min ago
I like transparency in the battery industry in China! Kudos
Barkuti
Barkuti's picture
Last seen: 1 day 12 hours ago
JaredM wrote:
Looks like. I didn't realize that LG changed their cell structure so much. Not only are the labels different, but now they use a '3-leg' positive pole like most other manufacturers. …
Only Samsung tops come close to that geometric shape, but still is easily discernible:
Left: this cell; right: Samsung 25S.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
shadockan
shadockan's picture
Not only Samy …
LG MH1 has the same …… I think …….
