Hey, these look nice! I don’t need one myself, but it looks like good work to me.
If you want your pictures to show up in-line, you will need to add a “!” to both sides of the link.
I like to also define a relative width (typically use 40) so it doesn’t display an image larger than the screen (really annoying on mobile). Anything up to 100 should be fine.
To get them to display, either use the “insert image” button or type the code into the editor (click the “quote” button on my post to see how I did this). Then your images will display on the forum like so:
I like C and D cell lights but I don’t like using alkalines and I like to have lights that can run on different “fuels”. The 3D printed adapters came out pretty nice, which is why I an offering them here.
Since Mag-Lite uses very chunky springs for the tail, I’d prefer the 18650 be in the middle of the adapter in this case, if possible. Could you make one that way? [Note: I’m not ready to buy right now, so don’t do it just for me.]
That’s kinda what I did for the D cell lights by using two adapters, one to change D cell to C cell and the other a C cell to 18650. There is a washer on the base of the D cell to C cell adapters that mates with unmodified Mag D cell springs so that there is no need for a spring mod.
I find that the smaller springs on C cell Mags work fine with 18650’s and even smaller cells.
I am working on a 21700 to 2C adapter. 21700’s maybe the ultimate “fuel” for a 2C light in terms of run time - I don’t know of anything with more Watt hours that will fit in a unmodified 2C tube.
Have you tried printing a 3C to 2x 18650 adapter for Defiant 3C light? The two 18650 cells would be connected in parallel to extend run-time. My Defiant 3C eats through a single NCR18650B cell very quickly.
I have sold most of these elsewhere and only have a few adapters left. Due to lack of access to a 3D printer during virus shut down, I will not be printing more for a while.
One of the last ones I completed is a 26650 to 3D cell adapter:
If I ever get a 6D ML300, I might come up with something to run a couple 26650 specifically for a 6D but 2 of the 3D to 26650 adapters would work just as well.
