Ran a capacity test on the 18650:s from Sofirn that came with the LT1 on my Opus and they deliver: 2951, 2952, 2985 and 2985 mAh.
3121, 3113, 3067, 3054 here.
Received mine yesterday, very pleased to learn that standard Sanyo GA cells work fine, no button tops needed.
Beautiful work, DBSAR! Also, ToyKeeper, Lexel, Del, Sofirn, and many others!
Just a heads up, mine was ordered on 10/12 , shipped via speedpak. So far speedpak with USPS sucks.went from DC to NJ , then to Indiana and next Kentucky. I am in Ohio . The updates for tracking happen seemingly the next day after it moves. It’s finally in Ohio. Should have it today or tomorrow. Again thanks for the team that made this.
I just had a chance to try out my first LT1. It will be a gift, so I didn’t really do a complete run-down. But it seems to work fine, and the candle flicker mode looks realistic. I didn’t find any manufacturing defects. It’s a very nice light. I left positive feedback for Sofirn in eBay, as they requested.
My LT1 has a problem.
After charging I found the USB port flap had come off. I am not rough with my lights. I have 3 Wubens that I have used more than the LT1 and never had a problem. I have a Nitecore several years old that has never had a problem. Not to mention a couple of phones with port flaps that have been used for 5 years or more and have the original flaps. Anyhow I thought I would mention it. I’ve sent a PM to Sofirn and to Barry. Here’s a photo.
ouch, did it just pop out or did the tab break?
I’ve had the same problems with the SP36. At least the LT1 driver comes out easily so pulling a new tab through the hole isn’t a big deal.
I thought the USB port flap coming out was a definite possibility when I got my LT. Hopefully Sofirn will make them available for sale when they inevitability get lost.
I need to order a half dozen or so SP36 versions. I might as well add a few of these to the list too.
The round stem that goes through the hole of the head body snapped. It appears to have broken off where I expect there is/was a larger ball or whatever, that is on the inside of the head to retain the opened flap. I simply pulled the little tab to open the flap and folded up to insert the USB plug and it came off in my fingers. Totally unexpected because, as mentioned, I have had good luck/experiences with port cover flaps on other lights and devices.
I hope they can at least send me a few, not just one and that it is not too difficult to insert.
I took a look inside my LT1, the rubber piece has a long . . .
nah, this needs a picture.
It looks like a replacement would feed through the body and one could grab the piece before the retention piece has to squeeze through the body. Likely a little isopropyl alcohol would help with the job also.
It looks like it broke right where the widened portion is. With length like that it should be easy enough to pull through. Thanks for the photo
I was about to forward this light to a relative in CA, but they are definitely not going to be able to install a new one themselves. So I’ll delay the sending I guess.
My pleasure.
I lost mine 2nd time out. It’s my hope they’ll offer The switch cover as well, just from experience I know I’ll need a few and possibly an o-ring or two. Oh and if ever offered I’d buy an extra shade or two.
I Do Like this lamp though. Other than these somewhat minor details the thing is built like a tank and runs for days.
There are 2 replacement port covers on the way to me. Thank you Barry and Zoe
Mine just arrived 30 minutes ago. Ordered 17 October after receiving Private Message with Group Buy Code from Sofirn. Man, I love this lantern! Thank you to DBSAR, Lexel, ToyKeeper and everyone who had a hand in the design,creation, programming and execution! The Anduril UI seems very intuitive after a couple of tries. I thought that the lantern would be bigger, I’m glad its not! Love it! I hope everyone that wants one gets one!
Best.
MtnDon
How did you go about this? I’ve lost my port cover and would like to get some switch covers as well. Just because
Thanks
Y usb port cover broke off so I contected Barry/Sofirn and they seny replacement. Maybe enquire thru their store about buying parts?
Thanks for the reply, what store address? Bit of a newb on the subject. Any help appreciated. I bought it through eBay. I did send a message there.
