The flashlight was gracefully provided by Sofirn’s Official store on AliExpress.
Here’s the product’s link in case you want to check it out: Sofirn C8T
The flashlight comes in a plain cardboard box - nothing to show here.
The accessories included are also quite minimal, in order to keep the price down.
In total, you get a lanyard, 2 spare o-rings and a bilingual user manual (EN and GE).
As indicated by its name, the flashlight is a C8 styled host.
The anodization creates an excellent satin black finish on the light.
I have to admit that I am very happy with the fit and finish of such a budget priced light.
As expected by a C8 styled host, you get some heatsink fins on the bottom of the head as well as some anti-roll grooves.
Of course, the flashlight is modder friendly and can be easily taken apart.
Here it is split on its basic pieces.
All of the body’s threads are square cut and arrived nicely lubricated.
It’s worth noting that the tail side threads are anodized, which allows the flashlight
to be locked out by a quarter turn of the tailcap.
A physical lock out is always nice to have, especially on high powered lights like this one.
The tailcap spring board is held in place by an aluminum retaining ring.
As you might notice, the light arrived with the tail spring bypassed by a silicone wire.
That’s some great attention to detail by Sofirn.
The FET driver is also held in place by a retaining ring.
Continuing the trend, the LED+ contact also arrived with the its spring bypassed.
In my case, the wire was loosely connected and it unsoldered itself once I run the light on Turbo for 3mins - No worries there, I resoldered it and it’s good to go.
The driver, that can also be purchased separately on Sofirn’s store, is powered by two FETs, a low power and a high power one.
You can see its performance on my tailcap readings below.
The C8T uses an XP-L Hi emitter with a neutral white color tint, while its reflector is smooth.
The emitter is aligned thanks to a centering ring.
I was quite surprised to see a 20mm Copper DTP star being used in there.
The star is secured in position with two screws and as seen, there is plenty of thermal paste applied
User Interface
The flashlight’s driver’s has two different mode groups that can be altered by a triple half press of the switch.
Group 1: Low > Mid > High
Group 2: Moonlight > Low > Mid > High > SOS (?)
The manufacturer describes the last mode as Strobe while in reality it’s an SOS/Bike Flash.
In order to access the actual Strobe, you need to do two quick half presses of the switch from any mode.
The moonlight mode is actually the lowest that I have seen in a flashlight.
I would estimated that it produces around a lumen of light.
The high mode does have a turbo timer set at 3 minutes. Once the timemark is reached, the driver will switch to medium mode.
Tailcal readings and beamshots
In order to get my readings, I used a clamp meter and a freshly charged 25R cell.
Keep in mind that being a FET driven flashlight, the High readings will vary depending on the quality of the cell that’s used
Mode - Current (A)
Low - 0.15
Mid - 1.52
High - 6.2
As one might expect, the flashlight starts getting quite warm after being left on high for more than 60 seconds. The 3min turbo timer should help you not getting a 3rd degree burn
Thanks to the XP-L Hi, the flashlight produces a very tight beam - more than half in size than my C8 with an XP-L.
An 70K - 80K throw should be easily achievable with Sofirn’s setup.
Here’s a wall beamshot that should help you see the mode spacing.
As a bottom line, I have to say that the C8T is the first C8 styled light that can really give Convoys a run for their money. It’s an excellent option for people that know what they really need, as FETs are not for everyone.
