[Review + Discussion] Nitecore TM9K
It is ugly
This is interesting. USB-C instead of micro-USB charging :+1: 9 emitter with 21700 is exactly what I was wishing Fireflies would come out with next. It might actually dethrone the Fireflies E07 as the brightest single cell flashlight. Looks wise it is not attractive. The heat fins are shallow unlike the E07, which I think looks better and performs better for heat shedding. I also dont like the fact that it cannot tail stand. I would buy it if they use 5000K emitters instead of CW but I doubt it.
Nice new release. There are very few multi emitter lights that use an efficient constant current driver. Too bad it uses a built in battery. That’s a deal breaker.
I wonder how open to persuasion the light is…
Nightwatch nsx3 3*xhp50.2 3V is rated 9900 lumen, single 21700. I dont think e07 í single cell brightest flashlight
We also have nitecore TM10k, which is also single cell flashlight and can do 10k lumen in……10s
Bat not removable
Yeah basically you are looking at a 12LED that pulls 35A and your runtime is zero. Supposedly there is no limit to how much direct driver one wants but at some point it becomes highly redundant to label how many lumens something does if the cells is empty in 2 seconds.
The point of these flashlights is not runtime, but to get the highest brightness at small form.
If i care about runtime, i won’t buy these
That turbo ready button seems weird. Seems flat like you can’t even press down on it. Would be hard to access with gloves.
Floody reflector lights this bright dont work all that well for actual real world use. Reason being is that the bright spill floods the foreground with too much light and blinds you. TIR lights are much better in this respect.
This light would have been way better with the KW CULNM1.TG LEDs.
Dont worry if it’s not bright enough… Next year I’m making a single cell light with 35000 lumens 2 seconds turbo runtime 10kcd. Built in fire extinguisher. 1300mah battery… and best of all it’ll only cost two kidneys.
Just because it has a poor skirt cap to protect the refill, it’s far from my interest. I am not against the possibility of charging, but a single rubber cap makes it too exposed to weather events
I’ve tested some Nightwatch lights before and their lumen ratings are exaggerated a bit. I’m guessing their 9,900 lumens is more like 7,000 lumens. Until someone on BLF measures with a calibrated lumen sphere, I’ll take it with a grain of salt.
Well said. :+1:
I saw in a video that the turbo lasts 7 sec.
I got one earlier this week, looks like a time step down at 7 second yup
Just a note, turbo is only momentary by holding down the dedicated turbo button, which makes a bit of sense with the rapid step down.
I look at it as a mini MS18. Capable of depleting almost all of its entire fuel supply in a brief brightest burst for size, if I want to. I ordered one, for starters.
I tested the Nitecore TM9K using the Texas Ace Lumen Tube calibrated with Maukka lights and a Sekonic C-800-U spectrometer. Output taken at 2s from turn-on.
Nitecore TM9K Turbo 8,190 lumens 6637K 0.0017 DUV 69.7 CRI Blue light relative amplitude 1.00 -25.2 R9 44.2 R12 65 Rf 96 Rg included battery
Nitecore TM9K M4 1,879 lumens 6247K 0.0057 DUV 69.0 CRI Blue light relative amplitude 1.00 -34.7 R9 41.2 R12 66 Rf 95 Rg included battery
Nitecore TM9K M3 446 lumens 6109K 0.0072 DUV 69.2 CRI Blue light relative amplitude 1.00 -37.1 R9 40.0 R12 67 Rf 95 Rg included battery
Nitecore TM9K M2 124 lumens 6121K 0.0066 DUV 69.1 CRI Blue light relative amplitude 1.00 -35.9 R9 40.5 R12 67 Rf 95 Rg included battery
Nitecore TM9K M1 33 lumens 6543K 0.0025 DUV 70.0 CRI Blue light relative amplitude 1.00 -26.6 R9 41.7 R12 66 Rf 96 Rg included battery
Note: the TA lumen tube gives lower readings for mules and extremely floody lights. I think we can add 5-10% to the measured output of this light.
The light looks good and it is extremely floody with a somewhat noticeable hotspot at the center. Makes for a great indoor light especially for large spaces. The output is really limited by the 5000K battery in it. I think it is a 50E or M50T rated at 10A continuous. If they used the brand new Samsung 50G rumored to have 15A continouous, it should be able to hit 10k lumens. I'm sure if it used a high current battery like the P42A or 40T, it can do 12k+. I know this is meant as a tactical light but I just wish it could tail stand. I don't like the CCT and tint though so probably won't ever use it as a tail stand light.
Thanks for the numbers SKV89! I've now finished my review and posted it to https://www.bmengineer.com/2020/03/nitecore-tm9k-review.html for anyone that wants to give it a read. I'll add a short summary to my original post as well.
For anyone thinking of buying, it's now available on Amazon.
