[Q] LED longevity -- there's hours, but what about on/off?
6 posts / 0 new
xevious
xevious's picture
Last seen: 8 hours 21 min ago
LED longevity is typically rated by hours of use (e.g. 10k, 20k, 50k). But I wonder… does the act of turning on an LED introduce some wear? It’s true for incandescent.
trakcon
trakcon's picture
Last seen: 5 hours 35 min ago
I’ve wondered this, too.
maukka
maukka's picture
Last seen: 10 months 2 days ago
Considering that LEDs are often turned on and off hundreds or thousands of times per second for prolonged periods I wouldn’t think it has an effect. Unless you are stressing them thermally with constantly doing some momentary turbo action on a hotrod and dunking them in an ice bath or something.
hIKARInoob
hIKARInoob's picture
Last seen: 8 hours 46 min ago
So this means there is not difference between a led turning on and off via PWM, and switching a led on and off with let’s say a clicky switch?
Barkuti
Barkuti's picture
Last seen: 3 hours 36 min ago
Incandescent is pretty on/off resilient; fluorescent can be a @#$%.
Led-wise the only thing which may complain is the driver, whatever it is. Of course I am namely speaking of AC/DC led drivers; and in my experience AC/DC led drivers are reliable, affordable and easily replaceable.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
xevious
xevious's picture
I hadn’t really thought about PWM because the “off” phase is so incredibly brief that the LED doesn’t have a chance to begin cooling off. But perhaps this does alleviate any concern for the diode, and that if there’s any wear to be concerned about it would be in the driver components.
