Received the LITNIT copper s2+ host I ordered from the convoy ali store today (very nice!) and the triple spacers and copper s2+ pill from kiriba-ru (also very nice!) and plan to do the build tomorrow. Triple lh351d 4000k 90 cri and optics from mtnelectronics, 12a ld-a4 driver… looking forward to seeing the build and results. There were 8 of the LITNIT left when I placed the order so I consider myself lucky. Very heavy for its size.
Those pills won’t work with the new copper s2+. The threading on litnit is more coarse. My heart was devastated and shattered my dreams when I found out the hard way.
I plan to use the pill from kiriba-ru in an aluminum s2 with the sst-40 5000k also from convoy and a narsil driver from lexel. The LITNIT came with a copper pill so I’ll only be using one of the spacers from kiriba-ru in that build. Based on the photos the tube threads looked more coarse and square than the aluminum s2+ (which sold me) and I suspected the same for the pill.
fwiw, i suspect the the litnit name and the emphasis was intended for the first i to be hard, as in “light’n it” similar to the hard vs soft i in the pronunciation of linux. if so, an excellent brand name.
Got my smooth copper S2+ yesterday and am pleased with the product. Machining and finish quality was just slightly below my other copper S2+ (from the first Convoy production run) but I’m not going to chase Simon for it as it’s minor.
It also came with copper pill and SST40 with ramping driver and with a Samsung 30Q it draws 7.7 amps at the tail cap! Gets hot quickly but I don’t need sustained 100% for long anyway so it’s fine with me. Very happy with the amount of light this thing throws out!
Whatever, but with standardized threads. It's a @#$% when for whatever reason shite happens.
While a tad off topic, certain manufacturers like Sofirn (for example) use propietary/different threading for their C8 flashlights, this means they don't lego with Convoy. If this happens within the same brand, $%&#€ #@%%€n$.
I’d like to see a c8+ style light with a copper head and aluminum bezel and tube with the aluminum anodized to a color similar to the brown the astrolux s41 baked to.
Yeah I agree, the Astrolux C8 looks OK and kudos to them for doing it in brass also but the C8+ design is so much nicer in my opinion. The knurling on the C8+ is also much better than the C8 :+1:
I haven’t acquired the spacer I need to build mine yet… but I’m thinking about lockout. As this is a copper light, I assume lockout will not be achieved by merely loosing the threads a tiny bit like with anodized aluminum bodies. Is this a correct assumption? Can someone who has managed to get their light built confirm?
I am not certain if the light is coated (had to hide it until I can finish it so I don’t spoil the surprise), but I am thinking there is a .04% chance this would allow for physical lockout if it is.
I tried the lockout with my smooth version. It works with loose threads and I had to take off the tail part to power off the light.
I think only the surface has a light coating because it still shiny.
I’m not too worried about the lack of physical lockout, but I wanted to know if a lighted tailswitch could be toggled this way. Looks like this light will not be getting AUX LEDs (fine be me… beautiful as is anyway).
I just tested the tint on the smooth copper S2+ with SST-20 2700K
With stock reflector and glass lens on max:
CCT: 2692K
DUV: 0.0027
Ra (CRI): 92.8
Blue peak: 0.24
R9: 69.0
R12: 82.0
Rf: 89
Rg: 102
With beaded optic and glass on max:
CCT: 2696K
DUV: 0.0005
Ra (CRI): 93.2
Blue peak: 0.28
R9: 71.3
R12: 84.7
Rf: 89
Rg: 103
With beaded optic and no glass on max:
CCT: 2700K
DUV: –0.0017
Ra (CRI): 93.7
Blue peak: 0.33
R9: 75.0
R12: 87.0
Rf: 87
Rg: 105
The beaded optic (available from Convoy store) looks much nicer. The stock reflector makes it look very yellow and has tint shift. With no glass and beaded optic, the tint is slightly rosy (negative duv).
Simon, is the beaded optic meant for use without glass? How is waterproofing?
Is there any practical use for the “faulty” square thread copper pills from Simon? Other than installing some emitter in and hanging them off the Christmas tree, ^:) that is. Suffice to say don't know what to do with them, just trying to find some creative use before throwing them away. They must be good for ≈1W of heat dissipation, doesn't it?
