That’s fine, but isn’t this the definition of a “tacticool” light?
I disagree. IMO a tactical light has one clicky on-off tail switch and no other UI options. Therefore, if this light has any additional options shouldn’t it be referred to as a “tacticool” light?
Personally I would really like a true tactical light at a bargain price, and YES I would trust it if it were half the price of name-brand tactical lights.
Whether or not this is the thread for this type of light remains to be seen, but so far it seems the goal of this flashlight project is to design a tacticool light, not a tactical light. Am I correct?
One bonus to a more complex driver is a settable high. The light should always come on in high mode, even if it’s just a one mode tactical light, but I prefer a rock steady ~500 lumen output and some people likely want it to come on at 1000+.
The concern is durability/reliability versus complexity. Can a complex driver be implemented in such a way that no amount of frantic manhandling or abuse will make it behave unexpectedly? The FW3A UI fails that criteria. Most non-tactical lights fail that criteria.
Bingo, one of my favorite features of Bistro/Biscotti is the mode groups that max out at 50%. I think holding an e-switch while cycling the light on/off is a pretty solid way of selecting these different mode groups, or a LARGE number of clicks that must be executed quickly.
It’s anecdotal, but none of the first responders, SAR volunteers, etc. that I know regularly use lights that are single-mode. It really demands always bringing a second light that has lower modes for everything else you would use a flashlight for. I know I wouldn’t trust this light for a weapon mount (okay, maybe for hunting) for years after its been disassembled, abused and analyzed by people smarter and harder on their tools than me.
I think most of the people here have their own ideas or definitions of what “tactical” means when used to describe a flashlight, because apparently there is no widely accepted definition of a “tactical” flashlight.
Maybe the solution is for someone to create a clearly defined list of features this light should have — and a corresponding list of features it should not have — and do not give it a descriptive name until the end, after all features are finalized and no longer debatable.
For that purpose the nitecore MT1A’s bezel works great for that, protection of the head but not destruction of the pocket. If you were to need an example.
That is absolutely implied. The term has been watered down over the years by pseudo-military marketing tomfoolery used by every ebay seller over thousands of mediocre products. This is why I am guessing there are a few of us watching this thread from the sidelines with a healthy amount of skepticism that a tactical light will be the final result.
And a budget Chinese tactical light is not impossible. People were carrying and weapon-mounting Fenix lights in Iraq and Afghanistan because SL/Surefire were ten years behind on LED tech at the time. The old Fenix lights were super simple, proven durable under extreme abuse, and nailed the fundamentals with modern battery and LED tech (although everyone in this case kept using cr123 because they were free).
But this is all working against the crowdfunding (or interest survey based) model you have here. Nobody who wants an actual tactical light is going to buy revision 1.0. We want abuse tests and months of documented reliability post-release. As someone who only buys lights when they get lost and only owns a handful of lights, I am intrigued with the quality of light this forum can produce — a fw3 replaced a 6 year old thrunite of mine that got lost. I’m also not convinced that this format of light is well served by the whims of a flashlight enthusiast internet forum. I apologize for being a negative nancy here.
What about the Luxeon V? They are available in 4000K, 5000K, 5700K and 6500K. The beam quality in an OP reflector should be great as well. I haven’t tried it in a SMO reflector yet.
My current tactical light is a Convoy M21A with OP reflector, LD-B4 driver 7 Amps, Luxeon V 5700K. No mode memory, mode sequence 100% - 16% - moon. So when I turn it on, I know it’s gonna full blast. A triple half tap and hold gives me strobe.
I would like a side switch on this project light with similar functionality to Acebeam and Olight. Otherwise I might as well stick to my reliable and powerful custom Convoy M21A.
It think you (should) know the objections against FET DD by now.
You will have to throttle the max output at max battery charge with unfortunate solutions like low drain batteries, high Vf LEDs, not optimal electrical path, PWM-ing too high currents, or simply overdriving the LED beyond preferable levels on a full battery.
This is all unnecessary with FET DD drivers, which aren’t even expensive anymore.
Even a 7135 driver works better than FET DD, in particular for modest output lights such as this project.
Don’t you prefer to have steady output levels? I know i do.
A nice buck driver on a low Vf LED may be even better, plus it makes it possible to use 2x CR123A.
These are more expensive though, but Convoy has the LD29, which could do with better mode spacing and more modes though.
I put a 4000K one in my Zanflare F1 and it really brought the F1 to life. :+1:
The low Vf of the Luxeon V makes the double click turbo of the F1 work throughout most of the battery charge, unlike with the XP-L it used to have.
The F1 has a SMO reflector, a fairly deep one, and it works great, and not a lot of tint shift.
Yes, the F1 is a bit large for a single 18650 light, but it’s a comfortable size to hold in your hand.
The only pity of the F1 is that the size could have fit a 21700.
You can’t drill out the battery tube though, because where the O-rings are the outer diameter is only 21mm.
But a 21700 would have justified the size of the F1.
BUT, as i mentioned earlier, they could have put an Omten 1288 in the side instead of the e-switch.
Plenty of room there.
But i don’t know of any decent light that comes with a reverse clicky side switch.
But i know it works just fine, because my last year’s failed scratch build had one and i modded 2 side e-switch lights into side reverse clicky lights.
